Posted: Tue May 21, 2013 1:24 am |
I got center-aligned PWM working with compiler vs. 4.141. I didn't try it
with any other version yet. To see it working, put your Channel 1
scope probe on Pin D7 and sync on that channel. Then put your Ch.2
probe on pin B0, or on pin B1. Channel 1 shows, roughly, the PWM
Timer status. You're looking at the PWM "cell" or time period.
Then when you look at pins B0 and B1 (which are complements of each
other, because we're running the PWM in Complementary mode) you
will see that when the duty cycle changes, it changes equally on both
sides of the PWM pulse. This demonstrates it is running in center-aligned
mode. If it was in normal "Free Run" mode, only one side of the pulse
would move when the duty cycle is changed.
#include <18F4431.h>
#fuses HS,NOWDT,PUT,BROWNOUT,NOLVP
#use delay(clock=20M)
// Note: The following numbers work with a 20 MHz oscillator frequency.
#define POWER_PWM_PERIOD 249 // Gives 10 KHz pwm freq with PWM_CLK_DIV_4
#define DEAD_TIME 2 // Gives dead time of 1.6 usec
// In the Up/Down Counting mode (Center-Aligned mode)
// an interrupt occurs each time the value of the PTMR
// register becomes zero and the PWM time base begins
// to count upwards.
// The PWMTB interrupt latency and interrupt handler
// overhead are at least 6 usec (at 20 MHz), so you
// see an edge on Pin D7 at least 6 usec after the
// middle of the center-aligned pulse. The purpose
// of this interrupt is so you can sync on Pin D7
// with your scope, and then look at the PWM output
// on pins B0 and B1. You can then see the PWM
// pulses expand or contract equally on both sides
// of the pulse as it switches between 40% and 60%
// duty cycle. This shows that it's doing center-
// aligned PWM.
#int_pwmtb
void pwmtb_isr(void)
output_toggle(PIN_D7);
// Setup PWM0 and PWM1 pins as complementary PWM outputs.
// All other PWM pins are configured as OFF (not used).
setup_power_pwm_pins(PWM_COMPLEMENTARY, 0, 0, 0);
// Mode = Up/Down Count
// Postscale = 1 (1-16) Timebase output postscaler
// TimeBase = 0 (0-65355) Initial value of PWM Timebase
// Period = 249 (0-4095) Max value of PWM TimeBase
// Compare = 0 (Timebase value for special event trigger)
// Compare Postscale = 1 (Postscaler for Compare value)
// Dead Time = 2
setup_power_pwm(PWM_UP_DOWN | PWM_CLOCK_DIV_4 | PWM_DEAD_CLOCK_DIV_16, 1, 0, POWER_PWM_PERIOD, 0, 1, DEAD_TIME);
// Enable PWM Timebase interrupts.
clear_interrupt(INT_PWMTB);
enable_interrupts(INT_PWMTB);
// Change the duty cycle every 1/2 second, as a demonstration.
// The last value in this line gives a 40% duty cycle.
set_power_pwm0_duty((int16)((POWER_PWM_PERIOD *4) * .4));
// The last value in this line gives a 60% duty cycle.
set_power_pwm0_duty((int16)((POWER_PWM_PERIOD *4) * .6));
jpos99
Posted: Thu May 23, 2013 7:47 am |
Thanks again PCM Programmer,
The code that you post works fine and I've made some changes.
#fuses INTRC_IO,NOWDT,PUT,BROWNOUT,NOLVP
#use delay(clock=8M)
// Note: The following numbers work with a 8 MHz oscillator frequency.
#define POWER_PWM_PERIOD 40 // Gives 25 KHz pwm freq with PWM_CLK_DIV_4
//#define DEAD_TIME 8
float adc_val;
// Setup pins as ODD ON PWM outputs.
setup_power_pwm_pins(PWM_ODD_ON, PWM_ODD_ON, PWM_ODD_ON, PWM_ODD_ON);
// Period = 40 (0-4095) Max value of PWM TimeBase
// Dead Time
setup_power_pwm(PWM_UP_DOWN | PWM_CLOCK_DIV_4 | PWM_DEAD_CLOCK_DIV_2, 1, 0, POWER_PWM_PERIOD, 0, 1, 0);
//clear_interrupt(INT_PWMTB);
//enable_interrupts(INT_PWMTB);
//enable_interrupts(GLOBAL);
setup_adc_ports(sAN0); //continuously sample and sync with PPWM
setup_adc(ADC_CLOCK_INTERNAL | ADC_CONT_A | ADC_WHEN_PPWM);
set_adc_channel(0);
delay_us(1);
adc_val = read_adc();
// The last value in this line gives a variable duty cycle given by a analog signal.
set_power_pwm0_duty((int16)((POWER_PWM_PERIOD *4) * (adc_val/255)));
set_power_pwm2_duty((int16)((POWER_PWM_PERIOD *4) * (adc_val/255)));
set_power_pwm4_duty((int16)((POWER_PWM_PERIOD *4) * (adc_val/240)));
set_power_pwm6_duty((int16)((POWER_PWM_PERIOD *4) * (adc_val/240)));
With this I have 4 PWM signal and 2 of them are +/- 500ns longer and center align.
But now I've realized that this is not quite what I was after .
I need to have 2 PWM signals with the same frequency but they are delayed T/2. As the code but one of the signals just happens half a period later with the same duty cycle.
Can I use the trigger to go to a interrupt and execute another pwm signal? This said do I have to setup another power pwm?
Thanks to all. |
jpos99
Posted: Thu May 23, 2013 10:51 am |
PCM Programmer,
I've been reading the PIC18F4431, and for what I read the Power PWM module is synchronous.
So what I want to do can not be done directly. I manage to do it with some signal manipulation and some values changes, but for some duty cycles the values change abruptly.
When I have the final solution or if I'm stuck again I post it here.
If you have any suggestion please feel free.
Thanks again all. |
jpos99
Posted: Fri May 24, 2013 3:37 am |
I've been reading and came across these image that controls the bridge like I want.
https://www.dropbox.com/s/2ktm2i0ngvphfpm/signals.jpg
Can anyone help me, because I'm not understanding one thing if the Power PWM is synchronous how can I delay one of the signals S3? Its by changing the time base value?
Thanks all |
Posted: Fri May 24, 2013 10:57 am |
| Post a link to the full web page where you got that timing diagram from. |
