ltc1298.c
Goto page Previous  1, 2, 3  Next
Mark
PostPosted: Tue Jan 25, 2005 5:44 pm     Reply with quote
Well the problem is his original post
hi can anyone help me please, can you please commentate the following codes? everything works now. im now able to read the voltage and hex via rs232. but i need to understand what the codes exactly do. thank you very much
Everything is working and he was just trying to understand it. Well it now sounds like:
Everything is working per the example but I want the output in decimal form instead of hex. I tried this..... but the results were not as expected. I am using a PICXXXX and compiler version XXXX.
Got to ask the right questions to get the right answer!
Guest_Me
PostPosted: Thu Jan 27, 2005 3:36 am     Reply with quote
hello.
i have another problem to solve.
how can i reverse the hex data. example:
3A20 to 02A3 ?
greetz
Mark
PostPosted: Thu Jan 27, 2005 7:57 am     Reply with quote
1. If you have converted it to a string, then just print it backwards.
2. Another option is to swap nibbles and then swap bytes. 3A20 -> A302 -> 02A3
rwyoung
PostPosted: Thu Jan 27, 2005 9:03 am     Reply with quote
Guest_Me wrote:
hello.
3A20 to 02A3 ?
greetz
This trick has been around for a while. The code below is for a 32-bit integer but you can modify it for 16-bit ints.
n = ((n >>  1) & 0x55555555) | ((n <<  1) & 0xaaaaaaaa) ;
n = ((n >>  2) & 0x33333333) | ((n <<  2) & 0xcccccccc) ;
n = ((n >>  4) & 0x0f0f0f0f) | ((n <<  4) & 0xf0f0f0f0) ;
n = ((n >>  8) & 0x00ff00ff) | ((n <<  8) & 0xff00ff00) ;
n = ((n >> 16) & 0x0000ffff) | ((n << 16) & 0xffff0000) ;
It is doing suggestion #2 from Mark's post (but on a 32-bit int).
Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
Mark
PostPosted: Thu Jan 27, 2005 9:23 am     Reply with quote
Wow! Now that is an equation. Here's something a bit simplier Very Happy
#include <16F877.h>
#use delay(clock=20000000)
  long int value;
  long int reversed;
  value = 0x3A20;
  #asm
    swapf value,0
    movwf &reversed+1
    swapf &value+1,0
    movwf reversed
  #endasm
Mark
PostPosted: Thu Jan 27, 2005 9:39 am     Reply with quote
Any if you don't like asm:
#include <16F877.h>
  long int value;
  union
    long int word;
    int8 b[2];
  } reversed;
  value = 0x3A20;
  reversed.b[1] = make8(value,0);
  reversed.b[0] = make8(value,1);
  swap(reversed.b[0]);
  swap(reversed.b[1]);
Guest_Me
PostPosted: Thu Jan 27, 2005 10:04 am     Reply with quote
hey guys... i believe, u misunderstood me..
3A20 to 02A3 ? -> thats was just an example..
when i use this ltc1298.c, the values that appear in Hyperterminal are somehow reversed....
so when it should show me 08A1 (dec. 2209) the program makes it reversed.. 1A80 (6784)... for my purpose its relevant if the programm just shows the decimal values..
i hope i've expressed myself clearly =)
thanks
rwyoung
PostPosted: Thu Jan 27, 2005 11:01 am     Reply with quote
thanks
Change the driver code to fill the 16-bit from the "other" end. Also you can get the data in either MSbit first or LSbit first from the LTC1298 itself by manipulating the MSBF bit in the control word or you can keep clocking more data out after the 12th bit without cycling the CS- pin at which time the LTC1298 will start sending out the last sample again but in reversed bit order.
Rob Young
PostPosted: Thu Jan 27, 2005 3:23 pm     Reply with quote
where exactly?
Mark
PostPosted: Thu Jan 27, 2005 3:34 pm     Reply with quote
I thought you read the datasheet?
http://www.linear.com.cn/pdf/128698fs.pdf
Look at pages 11 and 12. When the MSBF bit is set, you only get the data MSB to LSB. If MSBF is clear, then you get the data MSB to LSB and if you keep clocking you get LSB to MSB.
Mark
PostPosted: Thu Jan 27, 2005 3:41 pm     Reply with quote
Looking at this code
long int read_analog( BYTE channel ) {
   int l;
   long int h;
   delay_us(200);
   output_low(ADC_CLK);
   output_high(ADC_DIN);
   output_low(ADC_CS);
   if(channel==0)
     channel=0x1b;
     channel=0x1f;
   write_adc_byte( channel, 5);
   h=read_adc_byte(8);
   l=read_adc_byte(4)<<4;
   output_high(ADC_CS);
   return((h<<8)|l);
The channel value is the config byte or input data word. The word is actually only 3 bits but the code is writing 5 bits! This is why:
The first bit is actually a start bit and should always be a 1
The next 3 bits are the data word. Two for the address and 1 for the MSBF
The last bit or 5th bit is actually just a dummy clock cycle which would be the "NULL" bit.
PostPosted: Fri Jan 28, 2005 4:42 pm     Reply with quote
where exactly in the code should i change this?
Guest_Me
PostPosted: Fri Jan 28, 2005 4:52 pm     Reply with quote
oh now i understand, i have to change the 1b to 1a?
Guest_Me
PostPosted: Fri Jan 28, 2005 4:59 pm     Reply with quote
its me again =)
its not 1a but rather 19..am i right =)
but whats the 5th bit again? i can use either 1 or 0 ?
Mark
PostPosted: Fri Jan 28, 2005 11:05 pm     Reply with quote
Bits are clocked out LSB first. So 0x1B would be 0x13. The fifth bit is still the same as what I said before. It is the NULL bit. Read the datasheet and look at the timing diagrams and you will see it.
PS: Changing the config word isn't going to get you what you want unless you change the code to clock an additional 12 bits out which would be the reverse order. Read the datasheet, you will see it in there.
Page 2 of 3
