Crash when code size exceeds 32k
Goto page Previous  1, 2
PostPosted: Tue Aug 16, 2005 6:12 pm     Reply with quote
It may be that you have found a new silicon bug.
To try to narrow down the problem, I would disable anything unusual.
I notice that you're using the EMCU fuse. You might try disabling that,
and disable interrupts, and anything else that might cause the processor
to act weird. I assume that you'd have to add a little dummy code to
get the program out to the same size as before.
In this thread from late 2002, they're discussing a bug that occurs
when a jump or call is done across an address boundary, but your
problem occurs before a major boundary.
http://www.ccsinfo.com/forum/viewtopic.php?t=360
raljones
PostPosted: Wed Aug 17, 2005 12:55 pm     Reply with quote
I pretty much need all the interrupts I'm using, if I turn any off it won't work.
I've tried turning off the EMCU fuse. Kills external RAM access, but otherwise has no effect.
I'm still perusing the data sheet and erata documents.
Here is my port initialization. I think it's all ok.
I don't think I'm setting the "don't take BRA" bit.
void init_pic_io()   // initialize hardware
   setup_external_memory(EXTMEM_BYTE_SELECT);
   #USE STANDARD_IO(a)
   #USE STANDARD_IO(b)
   #USE STANDARD_IO(c)
   #USE STANDARD_IO(d)
   #USE STANDARD_IO(e)
   #USE STANDARD_IO(f)
   #USE STANDARD_IO(g)
   #USE STANDARD_IO(h)
   #USE STANDARD_IO(j)
   // Port A init
   output_low(PIN_A0);   // SCK - SPI bus clock
   output_low(PIN_A1);   // SDI - SPI bus Data in to peripheral
   output_float(PIN_A2);   // SDO - SPI bus Data out from peripheral
   output_high(PIN_A3);   // /CS A/D 24 bit REF / MEAS detectors
   output_high(PIN_A4);   // /CS A/D 12 bit TEMP / PWR / AUX
   output_low(PIN_A5);   // n/c
   output_high(PIN_A6);   // /reset out
   // Port B init
   output_float(PIN_B0);   // Interrupt input from keyboard
   output_float(PIN_B1);   // Interrupt input from Expansion module
   output_float(PIN_B2);   // Flow Switch input
   output_float(PIN_B3);   // Maintenence mode switch input
   output_float(PIN_B4);   // Front Panel Zero Button input
   output_float(PIN_B5);   // Front Panel Pressure Button input
   output_high(PIN_B6);   // PGC pin to programmer / debugger
   output_high(PIN_B7);   // PGD pin to programmer / debugger
   // Port C init
   output_low(PIN_C0);   // n/c
   output_low(PIN_C1);   // n/c
   output_low(PIN_C2);   // n/c
   output_low(PIN_C3);   // I2C SDA
   output_low(PIN_C4);   // I2C SCL
   output_low(PIN_C5);   // COM1, RS485 Driver Enable, Active High, receive mode default
   output_high(PIN_C6);   // COM1, RS485 TX Pin (don't init TX to low, screws things up!)
   output_float(PIN_C7);   // COM1, RS485 RX Pin
   // Ports D&E are used for External RAM access
   // Port D init
   // Port E init
   // Port F init
   output_float(PIN_F0);   // -RS232 select input      // 0 = selected
   output_float(PIN_F1);   // -RS485 select input      // only one of these 3 should
   output_float(PIN_F2);   // -Ethernet select input   // be selected at a time
   output_low(PIN_F3);   // Ethernet select output, 1 = power on to Ethernet port
   output_high(PIN_F4);   // -Ethernet reset output, 0 = reset Ethernet port
   output_low(PIN_F5);   // Lamp Control, 1 = lamp on
   output_low(PIN_F6);   // Heat On, 1 = heater on
   output_low(PIN_F7);   // Valve, 1 = Autozero Valve on
   // Port G init
   output_low(PIN_G0);   // COM2, RS485 Driver Enable, Active High, receive mode default
   output_high(PIN_G1);   // COM2 TX (don't init TX to low, screws things up!)
   output_float(PIN_G2);   // COM2 RX
   output_float(PIN_G3);   // AUX1, Optically isolated input
   output_float(PIN_G4);   // AUX2, Optically isolated input
   // Port H init
//   output_low(PIN_H0);     // XRAM A16
//   output_low(PIN_H1);     // XRAM A17
//   output_low(PIN_H2);     // XRAM A18
//   output_low(PIN_H3);     // XRAM A19
   output_low(PIN_H4);   // n/c
   output_high(PIN_H5);   // csx1
   output_high(PIN_H6);   // csx2
   output_high(PIN_H7);   // csx3
   setup_external_memory(0x31);   // byte select mode, 0 wait states
   dac_out(0);
   ibuf1[0] = '\x0';      // init com1 buffer
   bidx1 = 0;      // and index
   init_ibuf2();      // init buffer
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);
   set_timer1(62500);         // set for 10ms interrupt
   enable_interrupts(INT_TIMER1);   // allow timer interrupt
   enable_interrupts(INT_RDA);      // allow UART1 interrupt
   enable_interrupts(INT_RDA2);      // allow UART2 interrupt
Marko
PostPosted: Wed Aug 17, 2005 11:15 pm     Reply with quote
I have a similar problem with 18F6720, it hangs when I want to send data
over rs232. I discovered, that the TXSTAx register and some other registers are not set, but in the .lst file is all OK.
PostPosted: Thu Aug 18, 2005 1:00 am     Reply with quote
How much more do you want to experiment with this chip or this PIC ?
What if they didn't really fix the problem with corrupted instruction
fetches at frequencies above 4 MHz, that's mentioned in the A3 errata ?
If you want to do experiments, you could try locking out the compiler
from using the last 1 KB in that range. The #org statement shown below
will do that. This will force the compiler to move some functions above
the 0x8000 address boundary. The chip may behave differently.
I don't know -- do you want to trust it ? In the latest errata for the
Rev A4 chips, they still say it has the reset bug. CCS doesn't try to
compensate for that bug by implementing the suggested work around
of a NOP at 0x0000. CCS has a GOTO instruction at 0x0000.
You could try other things such as seeing if the problem is sensitive
to heat or cold: Freeze the PIC with freeze-spray.
#include <18F8720.H>
// Prevent the compiler from using the last 1KB in the first 32K of ROM.
#org 0x7C00, 0x7FFF {}
raljones
PostPosted: Thu Aug 18, 2005 1:14 pm     Reply with quote
Guess what?
I updated MPLAB from Ver 6.2 to Ver 7.0 and the problem vanished.
I guess this is why lots of other people weren't having this same problem.
Thank you all for your help, I'm going to get back to work.
PostPosted: Thu Aug 18, 2005 1:25 pm     Reply with quote
What do you think was causing the problem ?
Right here you said:
Without the debugger, it hangs, but there is no way to see where.
So that means the chip failed when running in standalone mode.
So how could MPLAB affect that ?
With the upgrade to vs. 7.20, you would likely get a new ICD2 firmware.
If the programming algorithm in the ICD2 wasn't working correctly
for the 18F8720, I suppose that bits in the program memory might
be flakey ? Bits in certain sections of memory might not be
programmed thoroughly enough, so that they could sometimes be
read as a 1 when they should be 0, and vice versa ? This might
explain it.
merca
Re:Crash when code size exceeds 32k
PostPosted: Fri Sep 16, 2005 4:21 am     Reply with quote
I have the same problem, and I would like to know if you are resolve the problem ?
I'm using 18F8720 and when I exceed 50% of ROM, the program no start at the power on.
I've compiled it on version 3.203 of CCS.
chargedneuron2
PostPosted: Tue Mar 25, 2008 1:21 am     Reply with quote
I have the same issue with the PIC16F77 with the v 4.069 compiler. Program hangs at power up when the code exceeds 50%
Anyone got an idea here?
chargedneuron2
PostPosted: Tue Mar 25, 2008 1:27 am     Reply with quote
Found my issue and I am not afraid to admit it was my fault... (sorta)
You MUST be sure that MPLAB has the correct device selected even if you select a device in CCS.
I called for a PIC16F77 but MPLAB was set to a PIC16F74. My ICD2 knew I didnt have the space to store my program and so it didnt program beyond 50%...
Page 2 of 2
