Lars Molnit Guest
V3.169 and ADC whit pic18f1320... crap |
Posted: Thu Jul 24, 2003 5:17 am |
What happendt, I got the 3.169 update, and then my 10bit AD doesent work any more... to get the corect value I have to use this line :
ADCValue=ADCValue>>6;
To get the right resoult ?????
The test code I use is hier :
#include <18F1320.h>
#device ADC=10
#fuses INTRC,NOWDT,PUT,BROWNOUT,BORV20,MCLR,NOLVP,NODEBUG
#use delay(clock=8000000) //8 MHz
#use rs232(baud=2400, xmit=PIN_B1, rcv=PIN_B4)
#byte OSCCON = 0x0FD3
unsigned int16 ADCValue=0x0000;
#use standard_io(A)
#use standard_io(B)
OSCCON = 0b11111001;
SETUP_ADC_PORTS(NO_ANALOGS | sAN0 | VSS_VDD);
SETUP_ADC(ADC_CLOCK_INTERNAL | ADC_TIME_0_TAD);
SET_ADC_CHANNEL(0);
while (1)
ADCValue=Read_ADC(ADC_START_AND_READ);
printf("\%lu \r",ADCValue);
Original Post ID: 144516309 |
hhoebel Guest
Re: V3.169 and ADC whit pic18f1320... crap |
Posted: Mon Jul 28, 2003 2:03 am |
i'm using too the 18F1320 with 3.169 and found a bug in the compiler itself. It took me a long time to find this. The compiler uses the wrong registers when using setup_adc.
When using setup_adc(ADC_CLOCK_DIV_16|ADC_TIME_20_TAD|ADC_START_ONLY) or something similar the compiler produces:
0926: MOVLW BD
0928: MOVWF FC2
092A: BSF FC2.0
which is definitly wrong, as this is the adcon0-register and the above settings are found in adcon2 (FC0).
With setting the register without "setup_adc" all works fine.
So simply use the #byte statement for setting up the adc instead of using setup_adc and it will work.
regards,
Heiko
P.S.: i send this to CCS but got no answer
Original Post ID: 144516419 |
ritchie
Posted: Wed Mar 03, 2004 9:21 am |
Lars Molnit wrote: | What happendt, I got the 3.169 update, and then my 10bit AD doesent work any more... to get the corect value I have to use this line :
#device ADC=10
#use standard_io(A)
#use standard_io(B)
SET_ADC_CHANNEL(0);
while (1)
OSCCON = 0b11111001; ---> is this really needed for a PIC18F1320 especially you use the internal oscillator?
Need comments please?
Thnx |
