I2C 1 Master 2 Slave
khienpzo
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger ICQ Number
PostPosted: Mon Nov 26, 2012 7:56 pm     Reply with quote
Hi, I am doing one project communication 1 master and 2 slave i2c read data from ADC 2 slave master and sent to the computer. I refer to the code of "PCM programmer" but I have not read the ADC data.
Master code:
#include <16f877a.h>
#include <def_877a.h>
#device *=16 ADC=8
#FUSES NOWDT, HS, NOPUT, NOPROTECT, NODEBUG, NOBROWNOUT, NOLVP, NOCPD, NOWRT
#use i2c(MASTER,SDA=PIN_C4,SCL=PIN_C3,fast)
#use RS232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#define slave_address1   0x10
#define slave_address2     0x20
char data1,data2 =0;
unsigned int16 control;
#INT_RDA
void ngatrs232()
   char c;
   c = getc();
   if (c=='a')
         putc(255);
         putc(255);
         delay_ms (10);
   if (c== 'b' )
         control = 1;
   if (c== 'f' )
         control = 2;
      control=0;
      data1 =0;
      data2 =0;
      enable_interrupts(INT_RDA);
      ext_int_edge(H_TO_L);
      enable_interrupts (GLOBAL);
      delay_ms(50);
      set_tris_D(0x00);
      set_tris_C(0x80);
      while(true)
            i2c_start();
               i2c_write(slave_address1);
               data1 = i2c_read(0);
               i2c_stop();
               delay_ms(10);
            i2c_start();
               i2c_write(slave_address2);
               data2 = i2c_read(0);
               i2c_stop();
               delay_ms(10);
            if (control == 1)
                  putc(data1);
                  putc(data2);
                  delay_ms(10);
code Slave 1
#device *=16 ADC=8
#use i2c (SLAVE,SDA=PIN_C4,SCL=PIN_C3,address=0x10,force_hw) // khai bao chuan truyen thong su dung//
int8 adc_result;
#INT_SSP
void ssp_interrupt()
   int8 incoming, state;
   state = i2c_isr_state();
   if(state < 0x80)     // Master truyen du lieu
            incoming = i2c_read();
   if(state >= 0x80)   // Master nhan du lieu tu Slave
            i2c_write(adc_result);
void main ()
setup_adc_ports(AN0);
setup_adc(ADC_CLOCK_DIV_8);
set_adc_channel(0);
delay_us(20);
adc_result = read_adc();
enable_interrupts(INT_SSP);
while(true)
code Slave 2
#device *=16 ADC=8
#use i2c (SLAVE,SDA=PIN_C4,SCL=PIN_C3,address=0x20,force_hw) // khai bao chuan truyen thong su dung//
int8 adc_result;
#INT_SSP
void main ()
set_adc_channel(0);
delay_us(20);
while(true)
PostPosted: Tue Nov 27, 2012 12:40 am     Reply with quote
You don't tell us what your problem actually is....
However killer code is doing two putc's and a delay in the INT_RDA. Multiple problems with this:
1) If data arrives while you are doing this, this _will_ hang the UART (add ERRORS to the RS232 declaration, and the compiler will add code to clear this).
2) Implies that all interrupts _will_ be disabled in the delays in the main....
Basically don't do this. If you must send from inside the interrupt, use a buffered TX. Or just use a flag and do the transmission in the external code. Never delay for more than a very few uSec in an ISR....
Other problem, is that you must read from the I2C, in state 0x80. Study the example code.
PostPosted: Tue Nov 27, 2012 6:02 am     Reply with quote
also ...
be sure to have the correct value resistors for the I2C bus lines.Usually 4k7 or 3k3 will work.
hth
jay
khienpzo
reply I2C
PostPosted: Tue Nov 27, 2012 7:38 am     Reply with quote
I use resistor 2k2 for I2C line.
