Rocky
TIMER1 interrupt |
Posted: Thu Sep 23, 2010 7:47 pm |
I am using a PIC18F23k20 and whatever I write to set_timer1(nnnn) the time between two interrupts is not changing. Looking at the .lst shows that the registers are written as expected. Changing the clock divider does change the time. What do I do wrong?
Same problem using timer0.
Thanks.
#int_TIMER1
void TIMER1_isr(void) // tick
output_toggle(PIN_C6);
time_count1++;
Intcount++;
if(Intcount > 14) //increment lapsed time
time_count2++;
Intcount = 0;
flag = TRUE;
//output_toggle(PIN_C6);
set_timer1(0x125);
unsigned long VCC =0.0, VMon =0.0;
unsigned long i=0, l = 0;
int1 done;
unsigned int j = 0;
setup_adc_ports(sAN0|sAN1|VSS_VDD);
setup_adc(ADC_CLOCK_DIV_2|ADC_TAD_MUL_0);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
set_timer1(0x125);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1);
setup_vref(FALSE);
//Setup_Oscillator parameter not selected from Intr Oscillator Config tab
//setup_oscillator(OSC_8MHZ|OSC_TIMER1);
clear_interrupt(INT_TIMER1);
ext_int_edge(H_TO_L); // init interrupt triggering for button press
// enable_interrupts(INT_EXT2);// turn on interrupts
set_tris_a(0xfb);
set_tris_c(0x3f);
set_tris_b(0xff);
read_adc(ADC_START_ONLY);
LED_RED_OFF;
LED_GREEN_OFF;
delay_ms(10);
output_b(0xff);
while(1) delay_ms(300); // 30 sec;
_________________ PERSEVERANCE IS THE KEY TO SUCCESS |
Posted: Thu Sep 23, 2010 8:36 pm |
1. Post a compilable program. Add the #include for the PIC, #fuses,
#use delay, etc.
2. Delete about 90% of your code, so the remaining code concentrates
on the Timer1 problem. Delete anything that isn't related to the problem.
3. Post a description of your external hardware, if it's related to the
test program.
4. Post your compiler version.
5. Describe your test environment. Is it Proteus ? Or is it a hardware
board ? |
Rocky
Timer1 interrupt |
Posted: Thu Sep 23, 2010 10:19 pm |
Thanks for the prompt reply PCM.
The compiler version is CCS PCH C Compiler, Version 4.106, 49215
I did paste what was in the main.h in the main.c for simplicity.
Whatever I write in set_timer1() I always get the same interval.
#include <18F23k20.h>
#device adc=10
#FUSES INTRC_IO //Internal RC Osc, no CLKOUT
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES NODELAYINTOSC
#use delay(clock=3900000)
//#use rs232(baud=9600,parity=N,xmit=PIN_C6,bits=8)
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
int16 Intcount=0,time_count1=0, time_count2=0;
int1 flag = 0;
#int_TIMER1
void TIMER1_isr(void) // 65.4ms tick
time_count1++;
Intcount++;
if(Intcount > 14) //increment ca every ...
time_count2++;
Intcount = 0;
flag = TRUE;
set_timer1(250);
setup_wdt(WDT_OFF);
set_timer1(0x250);
setup_timer_1(T1_INTERNAL | T1_DIV_BY_4);
setup_vref(FALSE);
set_tris_c(0x3f);
while(1) ;
Rocky
timer1 interrupt |
Posted: Thu Sep 23, 2010 11:03 pm |
Sorry, I forgot to mention that I run it on the real hardware and not simulation. For the sake of this problem the only relevant hardware is a darlington driving the LED.
PCM programmer wrote: | 1. Post a compilable program. Add the #include for the PIC, #fuses,
#use delay, etc.
test program.
board ? |
Posted: Fri Sep 24, 2010 2:30 am |
A few comments:
You are selecting INTRC_IO.
Your clock statement, selects 3.9MHz.
Is this an allowable combination for the chip?...
This will stop a lot of things from working as 'expected'.
How are you detecting the 'change' in output?.
The counter counts in 4*instruction time steps.
By the time you reach the interrupt, at least 30 instruction times _will_ have passed.
You then increment two 16bit variables (probably another dozen instructions), and at the 'minimum', do a value comparison as well (a few more). Probably something like 60 instruction times to the point where you set the timer. So the timer will have incremented by then, by perhaps 15 counts.
Given the total count is to 65536, the change between not setting the timer, and setting it to 250, will be about 65536/65301. 0.35% If you are using something like a scope, this will be completely in detectable.
ckielstra
Posted: Fri Sep 24, 2010 3:08 am |
A minor comment:and Quote: | set_timer1(0x250); | Be consistent in using decimal or hexadecimal.
Code: | setup_spi(SPI_SS_DISABLED); | This is a CCS setup wizard error. The parameter for disabling SPI should be changed to FALSE. |
Rocky
Re: timer1 interrupt |
Posted: Fri Sep 24, 2010 11:31 am |
ckielstra: thank you for the note on the setup_spi.
As for the timer I tried 8 and 16 bit and I didn't correct before sending.
INTRC is what I use and I tried INTRC_IO to see if it would make a difference but it doesn't.
tthelma: I measure the time on C6. it is toggled when I enter the interrupt and that is what I measure with a scope. The second C6 toggle is commented out.
I need to generate a timer interrupt every 5ms and be able to change it to 250ms and back to 5ms. I tried using timer0 but it shows the same problem. I am pretty sure I do something wrong but what?
Any further suggestion?
Thanks.
Rocky wrote: | Sorry, I forgot to mention that I run it on the real hardware and not simulation. For the sake of this problem the only relevant hardware is a darlington driving the LED.
#use delay, etc.
test program.
board ? |
Rocky
timer1 interrupt |
Posted: Fri Sep 24, 2010 12:45 pm |
ckielstra, I took your timer0 rtc example in another post and I had the same problem. Then instead of using set_timer0(250) I tried set_timer0(65000) and that changed the time as it should. It still was not wokring in 8bit mode and finally I found in the CCS help that 16 bit is the default mode and 8 bit must be set:
setup_timer_0(RTCC_INTERNAL | RTCC_DIV_1 | RTCC_8_BIT);
Yes, I did read the manual but missed that. :(
The reason I didn't see changes in 16 bit was that the value 250 was too low to see a significant change from 0.
Thanks to all who answered.
ckielstra wrote: | A minor comment:and Quote: | set_timer1(0x250); | Be consistent in using decimal or hexadecimal.
Posted: Fri Sep 24, 2010 2:16 pm |
Be aware that your timings will still not be right, if you do something like a 'delay' statement, unless you have fixed the clock statement. Your chip is _not_ running at 3.9MHz.
Rocky
TIMER1 interrupt |
Posted: Fri Sep 24, 2010 6:38 pm |
Yes, I did, thank you.
Ttelmah wrote: | Be aware that your timings will still not be right, if you do something like a 'delay' statement, unless you have fixed the clock statement. Your chip is _not_ running at 3.9MHz.
