infrared RC5 problem
ymoona
PostPosted: Mon Jun 05, 2006 10:52 am     Reply with quote
Hi
Im using an tsop 1736 to recieve rc5 codes. The out is connected to RB0 (int). im using an 18f2550 on an 20mhz xtal (internal freq is 48mhz)
the code I use I found on
http://www.ccsinfo.com/forum/viewtopic.php?t=4215&highlight=rc5+sony
and actualy it is working bit...
the only problem is that I have to push a button a few times (5 times or more) and then my USB is not working any more,
does anyone have working RC5 recieve and decode software wich is fully interupt driver?
checkout my site: www.ymoona.com/wiki
Ringo42
PostPosted: Mon Jun 05, 2006 1:35 pm     Reply with quote
Does this code really work? It looks like it is missing something. For example there is a #include with nothing following it, and I don;t see a #use232 type statement anywhere. Does anyone have to full code for this, it looks like fun to play with.
Ringo
Ringo Davis
ymoona
PostPosted: Mon Jun 05, 2006 2:24 pm     Reply with quote
Ringo
im not verry patient so I wrote some code that does decode rc5 codes
this one workt much better, but only it does not read the adress of the remote, ik shoult but it doesnot work. my code so far.
#include <18F2550.h>
#fuses NOMCLR,HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
//#fuses NOMCLR,HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL1,CPUDIV1,VREGEN
#use delay(clock=48000000)
//#use delay(clock=20000000)
#define ADC = 8
// CCS Library dynamic defines.  For dynamic configuration of the CCS Library
// for your application several defines need to be made.  See the comments
// at usb.h for more information
#define USB_HID_DEVICE     FALSE             //deshabilitamos el uso de las directivas HID
#define USB_EP1_TX_ENABLE  USB_ENABLE_BULK   //turn on EP1(EndPoint1) for IN bulk/interrupt transfers
#define USB_EP1_RX_ENABLE  USB_ENABLE_BULK   //turn on EP1(EndPoint1) for OUT bulk/interrupt transfers
#define USB_EP1_TX_SIZE    1                 //size to allocate for the tx endpoint 1 buffer
#define USB_EP1_RX_SIZE    3                 //size to allocate for the rx endpoint 1 buffer
#include <pic18_usb.h>     //Microchip PIC18Fxx5x Hardware layer for CCS's PIC USB driver
#include <Z:\Hobby\PC remote en LCD\software\firmware\USB_descriptor.h>
#include <usb.c>           //handles usb setup tokens and get descriptor reports
#include <Z:\Hobby\PC remote en LCD\software\firmware\flex_lcd420.c>
#define IR_SENSOR PIN_B0
#define IR (!input(IR_SENSOR))
// funtion prototypes
// hardware pin defines
#define modo      recive[0]
#define param1    recive[1]
#define param2    recive[2]
#define data send[0]
int8 pwm1=0;  // LCD backlite
int8 pwm2=0;  // contrast
int8 knipper=0;
int8 recive[3];                  //declaramos variables
//int8 send[1];
int8 send[1];
int1 irReady = false;
int8 irStart = 0;
int8 irCodeAdress =0;
int8 irCodeCommand = 0;
int i=0;
int32 iraantal= 0;
//externe interrupt door tsop
#int_ext
interrupt(){
   // based om http://www.xs4all.nl/~sbp/knowledge/ir/rc5.htm
   // zet de interrupts uit
   disable_interrupts(int_ext);
   irStart = 0;
   irCodeAdress =0;
   irCodeCommand = 0;
   // lees het eerste bit
   delay_us(480);
   if(IR){
      irStart += 1;
   irStart <<=1;
   // lees het twee bit
   delay_us(1778);
   if(IR){
      irStart += 1;
   irStart <<=1;
   // lees het derde bit
   delay_us(1778);
   if(IR){
      irStart += 1;
   //niet meer schuifen
   //irStart <<=1;
   // lees het vierde bit
   delay_us(1778);
   if(IR){
      irCodeAdress += 1;
   irCodeAdress <<=1;
   // lees het vijfde bit
   delay_us(1778);
   if(IR){
      irCodeAdress += 1;
   irCodeAdress <<=1;
   // lees het zesde bit
   delay_us(1778);
   if(IR){
      irCodeAdress += 1;
   irCodeAdress <<=1;
   // lees het zevende bit
   delay_us(1778);
   if(IR){
      irCodeAdress += 1;
   irCodeAdress <<=1;
   // lees het achtste bit
   delay_us(1778);
   if(IR){
      irCodeAdress += 1;
   // irCodeAdress <<=1;
   // lees het negende bit
   delay_us(1778);
   if(IR){
      irCodeCommand += 1;
   irCodeCommand <<=1;
   // lees het tiende bit
   delay_us(1778);
   if(IR){
      irCodeCommand += 1;
   irCodeCommand <<=1;
   // lees het elfde bit
   delay_us(1778);
   if(IR){
      irCodeCommand += 1;
   irCodeCommand <<=1;
   // lees het twaalfde bit
   delay_us(1778);
   if(IR){
      irCodeCommand += 1;
   irCodeCommand <<=1;
   // lees het dertiende bit
   delay_us(1778);
   if(IR){
      irCodeCommand += 1;
   irCodeCommand <<=1;
   // lees het veertiende bit
   delay_us(1778);
   if(IR){
      irCodeCommand += 1;
   //irCodeCommand <<=1;
   // klaar
   irReady = true;
void main(void) {
   setup_adc_ports(AN0_TO_AN1|VSS_VDD);
   setup_adc(ADC_CLOCK_DIV_2);
   setup_spi(FALSE);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DIV_BY_4, 127, 1);// PWM timer
   setup_vref(FALSE);
   setup_low_volt_detect(FALSE);
   setup_oscillator(False);
   enable_interrupts(int_ext);
   ext_int_edge(H_TO_L);                                                           //falling edge
   enable_interrupts(global);                                                            //enable interrupts
   setup_ccp1(CCP_PWM);  // zet beide Compare units op PWM
   setup_ccp2(CCP_PWM);
   set_pwm1_duty(100);// backlite
   set_pwm2_duty(0);  // contrast
   delay_ms(10);
   lcd_putc("\f");
   lcd_putc(" USB remote and LCD \n");
   lcd_putc("      made by       \n");
   lcd_putc("   Hans de Groot    \n");
   lcd_putc("Versie 0.1 04/06/06 \n");
   usb_init();                      //init USB
   usb_task();                      //hoort ook bij de init
   usb_wait_for_enumeration();      //wacht op herkenning door de host PC
   while (TRUE)
      if(irReady){
         irReady = false;
         printf(lcd_putc,"\fstart:%u \nadress:%u\ncommand:%u \nir:%Lu",irStart, irCodeAdress, irCodeCommand, iraantal);
         iraantal++;
      if(usb_enumerated())          //zolang de USB is geconfigureert
         if (usb_kbhit(1))          //if endpoint of exit contains data of host
            usb_get_packet(1, recive, 3); //cojemos the package of size 3bytes of the EP1 and we stored in receives
            // welke modus is gestuurt?
            if (modo == 0) {// PWM moet aangestuurt worden
               if (param1 == 1) {
                  set_pwm1_duty(param2);
               if (param1 == 2) {
                  set_pwm2_duty(param2);
            if (modo == 1 || modo == 2 || modo == 3 || modo == 4){ // lcd
               if(param1 <= 20){
                  lcd_gotoxy(param1,modo);
                  lcd_putc((char)param2);
