GPS - string garbage
pilar
PostPosted: Wed Jul 22, 2009 4:22 pm     Reply with quote
Hi, I am trying to capture a message of string NMEA of a GPS, specifically the GPRMC, I have implemented this code with the examples of this forum, the problem is that the buffer NMEA_RMC[] there are only trash, Evil or Very Mad which is my mistake?
Question This is the message that I'm looking for
"$GPRMC,144055.000,A,1209.1120,S,07701.3939,W,0.05,70.22,180209,,*34"
#include <18F452.h>
#include <string.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP,PUT
#use delay(clock=20000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)// RS232 Estándar
char NMEA_RMC[58] ;
#include <STDLIB.H>
#include <MATH.H>
#define BUFFER_SIZE 58
int8 buffer[BUFFER_SIZE];
int8 next_in = 0;
int8 next_out = 0;
int xbuff=0x00;
char GPS_OK = 0;
#INT_RDA
void serial_isr() {                       // Serial Interrupt
   int t;
   buffer[next_in]=getc();
   t=next_in;
   next_in=(next_in+1) % BUFFER_SIZE;
   if(next_in==next_out)
     next_in=t;                       // Buffer full !!
#define bkbhit (next_in!=next_out)
int8 bgetc() {
   BYTE c;
   WHILE(!bkbhit) ;
   c=buffer[next_out];
   next_out=(next_out+1) % BUFFER_SIZE;
   return(c);
void Ini_NMEA_RMC(void){       // Inicia a \0 cbuff -------------------
  int i;
  int count=58;
  for(i=0;i<count;i++){     // Bucle que pone a 0 todos los
    buffer[i]=0x00;          // caracteres en el buffer
  xbuff=0x00;               // Inicializo el índice de siguiente
   int8 n = 0;
   int32 i =0;
   int8 theChar = 0;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_spi(FALSE);
   setup_wdt(WDT_OFF);
   enable_interrupts(global);
   enable_interrupts(int_rda);
   delay_ms(50);
do{
      GPS_OK == 0;
         WHILE (theChar != '$') theChar = bgetc();                              // Look for a '$' - the start of a NMEA sentence
         theChar = bgetc();
         IF (theChar == 'G') {
            theChar = bgetc();
            IF (theChar == 'P') {
               theChar = bgetc();
               IF (theChar == 'R') {
                  theChar = bgetc();
                  IF (theChar == 'M') {
                     theChar = bgetc();
                     IF (theChar == 'C') {
                        theChar = bgetc();                                       // Discard ','
                        theChar = bgetc();                                       // Discard Time
                        WHILE (theChar != ',') theChar = bgetc();
                  xbuff =0;
                  Ini_NMEA_RMC();
                  while (theChar != '*'){
                  NMEA_RMC[xbuff++] = bgetc();
                  GPS_OK == 1;
}   while (GPS_OK == 0);
PostPosted: Wed Jul 22, 2009 4:55 pm     Reply with quote
NMEA-0183 is 4800 baud. See this article:
http://en.wikipedia.org/wiki/NMEA_0183
pilar
PostPosted: Wed Jul 22, 2009 5:00 pm     Reply with quote
Hi, PCM programmer, this GPS is to 9600KB, because when I use the Hyperterminal it is OK.
PostPosted: Wed Jul 22, 2009 5:09 pm     Reply with quote
Instead of running the message through your "if" statement code, just
send the data from the buffer to your PC and look at it in a terminal
window. Then you can tell if it's being received properly by your PIC.
ckielstra
PostPosted: Wed Jul 22, 2009 5:10 pm     Reply with quote
                  xbuff =0;
                  Ini_NMEA_RMC();
The call to Ini_NMEA_RMC() has several problems:
1) It will erase data already received in the background, causing data loss.
2) The received data buffer will be empty, but the next_in and next_out variables are not reset. If data was present before resetting the buffer this will cause problems.
There is no need to reset the buffer to all zeroes, so get rid of this call.
The while loop will never exit as variable theChar never changes inside the loop.
Change to something like:
                  xbuff =0;
                  do {
                    theChar = bgetc();
                    NMEA_RMC[xbuff++] = theChar;
                  } while (theChar != '*');
pilar
PostPosted: Wed Jul 22, 2009 5:27 pm     Reply with quote
Very Happy thank you
PostPosted: Wed Jul 22, 2009 8:38 pm     Reply with quote
Maybe this is not so important with a circular buffer, but your buffer size is only 58 characters, whereas the receive string is 65+ characters. This means that you won't even get the whole string in the receive buffer before it wraps around. I don't see any good reason to do this.
George
bkamen
PostPosted: Wed Jul 22, 2009 8:47 pm     Reply with quote
Anonymous wrote:
Good point, George. It is important.
The NMEA "manual" from Garmin is pretty nice in that it tells you, "this sentence will give you at maximum this many characters".
You should make your buffer at least that big.
I did a GPS parsing routine for both the Garmin 16/17 series OEM sensors as well as the DeLorme GPS2058.
Both work as they should because they have enough buffer space and are state machine driven.
Your ISR just stuffs chars into a buffer until it's done. try waiting until the beginning of a sentence ( marked by '$') and THEN storing the string until it ENDS with a CR or LF (you should get both) and then flag the buffer as ready and then process it. Look at the beginning of the sentence and if it's not GPRMC, dump the buffer and get the next. (I happen to copy the buffer immediately and then release the state machine to continue running to gather the next sentence while I process the one I have)
Regards,
-Ben
Dazed and confused? I don't think so. Just "plain lost" will do. :D
jma_1
PostPosted: Sun Jul 26, 2009 1:55 pm     Reply with quote
Greetings,
As an off topic to the already addressed problem, PCM programmer correctly lists the standard NMEA-0183 baud rate at 4800. Another high speed version of this exists and is 38400 baud. Any other baud rates are non-standard and do not follow the NMEA spec.
Cheers,
JMA
gamal eldeen
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Sat Aug 04, 2012 6:48 am     Reply with quote
please i want to understand the interrupt
   int t;
how the
 [next_in]
increment to full in the
buffer
bkamen
PostPosted: Sat Aug 04, 2012 8:41 am     Reply with quote
Look up ring or circular buffers and how they work. That's the explanation you're searching for.
