Shep Guest
ASM table reads |
Posted: Thu Sep 30, 2004 5:36 am |
Hi all,
How do you extract the address of a const array for use with table reads?
i.e. :
int const lookup[16] = {0 1 2 3 ...};
#ASM
MOVLW who?
MOVWF TBLPRTU
MOVLW what?
MOVWF TBLPRTH
MOVLW where?
MOVWF TBLPRTL
TBLRD*
MOVFF TBLLAT, Result
#ENDASM
cheers |
Posted: Thu Sep 30, 2004 1:20 pm |
The method shown below appears to work. This was tested with
PCH vs. 3.188. To verify that it works with your version of the
compiler, you should check the .LST file and the Program Memory
window (to see the location of the ROM data in the lookup array).
Code: | #include <18F458.H>
#fuses XT, NOPROTECT, PUT, NOBROWNOUT, NOWDT, NOLVP
int const lookup[4] = {0, 1, 2, 3};
main()
int16 addr;
addr = label_address(lookup);
Shep Guest
Posted: Thu Sep 30, 2004 2:49 pm |
Don't appear to work that one. my compiler is 3.123
and i get:
Error[72] main.c 25 : Incorrectly constructed label |
