Joined: 07 Jan 2004 Posts: 1619 Location: Central Illinois, USA
PIC16F629 Quirk??
Posted: Sat Feb 05, 2005 11:05 pm
OK, I've set up my IRQ ISR to handle RA.. no problem... but RA0 and RA1 weak pullups aren't even on (even though I use port_a_pullups(true) and (0x0F)).
I've even soldered some pullups in place (10k) and still nothing happens when grounded like RA2 and RA3 both show.
Anyone notice quirks with the F629 like this?
-Ben
Posted: Sat Feb 05, 2005 11:38 pm
You have to disable the comparators by using this line of code:
Depending on your version of the compiler, that line of code may
not work. If that's the case, then you can turn them off manually
with this:
#byte CMCON=0x19
CMCON=7;
// Put the rest of your program here.
bkamen
Posted: Sun Feb 06, 2005 12:39 am
That's the right option listed in 12f629.h from CCS and work.
I looked at the register table and it's power on state is enabled. Yeesh! Subtle.
