Same program but different results why !?!??!!?
Garath
PostPosted: Fri Feb 22, 2002 9:46 am     Reply with quote
Hie, i wrote 2 programs which have exactly the same code but when compiled, the 1st program works fine but the 2nd program doesn't work. Could someone please tell me why.
When a low is applied to RB0 the program is supposed to transmit 'c' to the computer.
//This is the code that works//
#include<c:\16f84.h>
#use fast_io(A)
#use fast_io(B)
#byte _portA = 5
#byte _portB = 6
#use rs232 (baud=9600,xmit=pin_a1,rcv=Pin_a2, parity=N, bits=8, restart_wdt)
int main(void);
void reset(void); //ch//
int main()
//int i;
reset();
return;
//set_tris_b(0xff);
//set_tris_a(0x00);
void reset()
int i;
reloop: set_tris_a(0x00); //set all portB as output//
_portB = 0x01;
delay_us(10); //change//
bit_clear(_portB,0); //low reset pulse for minimum of 480us//
delay_us(500);
bit_set(_portb,0); //VPullup//
delay_us(100);
//receive mode//
i = bit_test(_portB,0);
if (!i)
delay_us(500);
printf(" C ");
delay_us(400);
delay_us(500);
goto reloop;
return;
//This doesn't work//
#use fast_io(A)
#use fast_io(B)
#byte _portA = 5
#byte _portB = 6
#use rs232 (baud=9600,xmit=pin_a1, rcv=Pin_a2, parity=N, bits=8, restart_wdt)
int main(void);
void reset(void);
int main()
reset();
return;
void reset()
{ //reset pulse//
int i;
reloop: set_tris_B(0x00); //set all portB as output//
_portB = 0x01;
delay_us(10);
delay_us(500);
delay_us(100);
//receive mode//
if (!i)
printf(" c ");
delay_us(400);
delay_us(500);
goto reloop;
return;
Original Post ID: 2761
Todd C. Micallef
Re: Same program but different results why !?!??!!?
PostPosted: Fri Feb 22, 2002 9:57 am     Reply with quote
Hi, I hate to state the obvious but your first program has a set_tris_A
and the second has a set_tris_B
:=Hie, i wrote 2 programs which have exactly the same code but when compiled, the 1st program works fine but the 2nd program doesn't work. Could someone please tell me why.
:=When a low is applied to RB0 the program is supposed to transmit 'c' to the computer.
:=//This is the code that works//
:=#include<c:\16f84.h>
:=#use delay(clock=4000000)
:=#use fast_io(A)
:=#use fast_io(B)
:=#byte _portA = 5
:=#byte _portB = 6
:=#use rs232 (baud=9600,xmit=pin_a1,rcv=Pin_a2, parity=N, bits=8, restart_wdt)
:=int main(void);
:=void reset(void); //ch//
:=int main()
:=//int i;
:=reset();
:=return;
:=//set_tris_b(0xff);
:=//set_tris_a(0x00);
:=void reset()
:=int i;
:=reloop: set_tris_a(0x00); //set all portB as output//
:= _portB = 0x01;
:= delay_us(10); //change//
:= bit_clear(_portB,0); //low reset pulse for minimum of 480us//
:= delay_us(500);
:= bit_set(_portb,0); //VPullup//
:= delay_us(100);
:= //receive mode//
:= i = bit_test(_portB,0);
:= if (!i)
:= delay_us(500);
:= printf(" C ");
:= delay_us(400);
:= else
:= delay_us(500);
:= goto reloop;
:= return;
:=//This doesn't work//
:=#use fast_io(A)
:=#use fast_io(B)
:=#byte _portA = 5
:=#byte _portB = 6
:=#use rs232 (baud=9600,xmit=pin_a1, rcv=Pin_a2, parity=N, bits=8, restart_wdt)
:=int main(void);
:=void reset(void);
:=int main()
:=reset();
:=return;
:=void reset()
:={ //reset pulse//
:=int i;
:=reloop: set_tris_B(0x00); //set all portB as output//
:= _portB = 0x01;
:= delay_us(10);
:= delay_us(500);
:= delay_us(100);
:= //receive mode//
:= if (!i)
:= printf(" c ");
:= delay_us(400);
:= else
:= delay_us(500);
:= goto reloop;
:= return;
:=Thanks
Original Post ID: 2762
