funny adc output
jubilee
funny adc output
PostPosted: Tue Aug 26, 2003 11:22 pm     Reply with quote
Hi i amhaving a tough time solving the problem i have been facing. It is like this=== i am having a input from a power supply. using a PIC , i am required to readout the voltage and output it to the PC. Using the following codes..., i am getting some increadible values like 1000++ values. IS there anything worng with the codes??
PLeasseeeee HELP!!
setup_adc_ports(RA0_RA1_RA3_ANALOG);
setup_adc(ADC_CLOCK_DIV_2);
setup_spi(FALSE);
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
setup_timer_1(T1_DISABLED);
setup_ccp1(CCP_OFF);
setup_ccp2(CCP_OFF);
long value,min,max,mean,old,new,total;
int i;
printf("Sampling:");
do {
min=255;
max=0;
old,new,total=0;
for(i=0;i<=100;++i) {
delay_ms(5);
value = Read_ADC();
new=value;
total=old+new;
if(value min=value;
if(value>max)
max=value;
mean=(max + min)/2;
old=total;
mean=old/100;
printf("\n\rMean: \%4lu Max: \%4lu\r\n",mean,Max);
printf("\n\rold: \%4lu Max: \%4lu\r\n",old,Max);
} while (TRUE);
Original Post ID: 144517295
Kenny
Re: funny adc output
PostPosted: Wed Aug 27, 2003 1:01 am     Reply with quote
<font face="Courier New" size=-1>:=Hi i amhaving a tough time solving the problem i have been facing. It is like this=== i am having a input from a power supply. using a PIC , i am required to readout the voltage and output it to the PC. Using the following codes..., i am getting some increadible values like 1000++ values. IS there anything worng with the codes??
:=PLeasseeeee HELP!!
:= setup_adc_ports(RA0_RA1_RA3_ANALOG);
:= setup_adc(ADC_CLOCK_DIV_2);
:= setup_spi(FALSE);
:= setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
:= setup_timer_1(T1_DISABLED);
:= setup_timer_2(T2_DISABLED,0,1);
:= setup_ccp1(CCP_OFF);
:= setup_ccp2(CCP_OFF);
:= long value,min,max,mean,old,new,total;
:= int i;
:= printf("Sampling:");
:= do {
:= min=255;
:= max=0;
:= old,new,total=0;
:= for(i=0;i<=100;++i) {
:= delay_ms(5);
:= value = Read_ADC();
:= new=value;
:= total=old+new;
:= if(value := min=value;
:= if(value>max)
:= max=value;
:= mean=(max + min)/2;
:= old=total;
:= mean=old/100;
:= printf("\n\rMean: \%4lu Max: \%4lu\r\n",mean,Max);
:= printf("\n\rold: \%4lu Max: \%4lu\r\n",old,Max);
:= } while (TRUE);
Funny indeed :-)
Several problems apparent.
Since PIC type or clock frequency not given, I'll assume a 16F876 and >= 4MHz.
The maximum clock frequency is 1.25MHz for this division, change to:
setup_adc(ADC_CLOCK_DIV_32);
Need to select a/d channel
eg.
set_adc_channel(0); // Select channel 0
From your code you seem to be doing 8 bit a/d
Check that it's not set for 10 bit in the 16F876.h file as:
#device PIC16F876 ADC=10
Also, in the code, variables will accumulate past the 16 bit boundary and wrap, but your not seeing that because the output is limited to four digits.
Modified code:
long total;
int min,max,mean,new,i;
printf("Sampling:\n\r");
while (1) {
min=255;
max=0;
new = 0;
total=0;
delay_ms(5);
new = read_adc();
if(new < min) min = new;
if(new > max) max = new;
total += new;
mean = total/100;
printf("Max: \%3u Min: \%3u Mean: \%3u\n\r",max,min,mean);
HTH
Kenny
</font>
Original Post ID: 144517303
R.J.Hamlett
PostPosted: Wed Aug 27, 2003 2:24 am     Reply with quote
What clock rate is your chip?. This may be faster than the ADC can properly run.
:= int i;
:= do {
:= min=255;
:= max=0;
:= old,new,total=0;
This is not the way to clear three variables. The syntax is:
old=new=total=0;
:= delay_ms(5);
If you want only 8bit values, then on most chips, you will need to specify #device adc=8
This has changed from older compilers, where the default was 8bit, unless told otherwise. Now the compiler appears to default to the full ADC resolution, unless told otherwise. Hence on most chips, I'd expect this call to return 0-1023.
Nowhere in the code, have you set _which_ ADC channel is to be read...
:= new=value;
:= total=old+new;
:= if(value>max)
:= max=value;
This does nothing, since 'mean', gets overwritten when you leave the loop, with the value 'old/100', and 'mean' is not being used anywhere in the loop. Hence this calculation is wasted...
:= old=total;
:= mean=old/100;
You have an error here, since the loop will execute 101 times (0 to 100 inclusive).
You are also wasting quite a bit of time, moving numbers around. Clear 'old' when you come into the loop (you allready try to do this), then just have:
for(i=0;i<100;++i) {
delay_ms(5);
value = Read_ADC();
old+=value;
if(value min=value;
if(value>max)
max=value;
:= } while (TRUE);
Original Post ID: 144517306
