I2C 100kHz or 400kHz
Emil Kartasian
PostPosted: Mon Aug 11, 2003 12:48 am     Reply with quote
When they say the chip is ok for 100kHz or 400kHz and to use 2k
resistor for higher freq and 10 k for lower. Does this mean I can choose the speed? Also do I need a pullup for both SCL and SDA? Thanks.
Original Post ID: 144516870
Kenny
Re: I2C 100kHz or 400kHz
PostPosted: Mon Aug 11, 2003 1:22 am     Reply with quote
:=When they say the chip is ok for 100kHz or 400kHz and to use 2k
:=resistor for higher freq and 10 k for lower. Does this mean I can choose the speed? Also do I need a pullup for both SCL and SDA? Thanks.
If the chip supports fast mode then you can select the speed.
If no speed is specified in the #use i2c statement then it defaults to 100kHz.
#use i2c(master,sda=PIN_C4,scl=PIN_C3) // 100kHz
For fast
#use i2c(master,sda=PIN_C4,scl=PIN_C3,FAST) // 400kHz
Yes, you need pullups on both SCL and SDA.
There is a 400pF capacitance limit on the bus so around 2k2
should be used for fast mode so that the edges are fast enough.
Also, keep distances as short as possible.
See the i2c bus specifications for more detail.
<a href="http://www.semiconductors.philips.com/buses/i2c/" TARGET="_blank">http://www.semiconductors.philips.com/buses/i2c/</a>
Kenny
Original Post ID: 144516872
Emil Kartasian
PostPosted: Mon Aug 11, 2003 6:04 am     Reply with quote
The chip I have is 24C02N. Will this support fast mode?
:=:=When they say the chip is ok for 100kHz or 400kHz and to use 2k
:=:=resistor for higher freq and 10 k for lower. Does this mean I can choose the speed? Also do I need a pullup for both SCL and SDA? Thanks.
:=If the chip supports fast mode then you can select the speed.
:=If no speed is specified in the #use i2c statement then it defaults to 100kHz.
:=#use i2c(master,sda=PIN_C4,scl=PIN_C3) // 100kHz
:=For fast
:=#use i2c(master,sda=PIN_C4,scl=PIN_C3,FAST) // 400kHz
:=Yes, you need pullups on both SCL and SDA.
:=There is a 400pF capacitance limit on the bus so around 2k2
:=should be used for fast mode so that the edges are fast enough.
:=Also, keep distances as short as possible.
:=See the i2c bus specifications for more detail.
:= <a href="http://www.semiconductors.philips.com/buses/i2c/" TARGET="_blank"> <a href="http://www.semiconductors.philips.com/buses/i2c/" TARGET="_blank">http://www.semiconductors.philips.com/buses/i2c/</a></a>
:=Kenny
Original Post ID: 144516879
thomas
PostPosted: Mon Aug 11, 2003 1:56 pm     Reply with quote
With software I2C, what's the minimum crystal speed in order to get 400Khz I2C speed?
Regards,
Thomas
:=For fast
:=Kenny
Original Post ID: 144516896
Kenny
PostPosted: Mon Aug 11, 2003 4:47 pm     Reply with quote
:=Hi,
:= The chip I have is 24C02N. Will this support fast mode?
The data sheet says 100kHz so the answer is no.
:=:=:=When they say the chip is ok for 100kHz or 400kHz and to use 2k
:=:=:=resistor for higher freq and 10 k for lower. Does this mean I can choose the speed? Also do I need a pullup for both SCL and SDA? Thanks.
:=:=If the chip supports fast mode then you can select the speed.
:=:=If no speed is specified in the #use i2c statement then it defaults to 100kHz.
:=:=#use i2c(master,sda=PIN_C4,scl=PIN_C3) // 100kHz
:=:=For fast
:=:=#use i2c(master,sda=PIN_C4,scl=PIN_C3,FAST) // 400kHz
:=:=Yes, you need pullups on both SCL and SDA.
:=:=There is a 400pF capacitance limit on the bus so around 2k2
:=:=should be used for fast mode so that the edges are fast enough.
:=:=Also, keep distances as short as possible.
:=:=See the i2c bus specifications for more detail.
:=:= <a href="http://www.semiconductors.philips.com/buses/i2c/" TARGET="_blank"> <a href="http://www.semiconductors.philips.com/buses/i2c/" TARGET="_blank"> <a href="http://www.semiconductors.philips.com/buses/i2c/" TARGET="_blank">http://www.semiconductors.philips.com/buses/i2c/</a></a></a>
:=:=Kenny
Original Post ID: 144516903
