PWM on 12f675
Mick Kent
PWM on 12f675
PostPosted: Fri Aug 08, 2003 1:32 pm     Reply with quote
I am trying to use timer0 and timer1 interrupts to generate a PWM signal on pin_A2. I used 3.169 and the wizard. My non working code follows:
#include <12F675.h>
#device adc=10
#fuses INTRC, MCLR, BROWNOUT, NOWDT
#rom 0x3FF = {0x3470}
#define PWMout PIN_A2
#byte ANSEL=0x9f
int16 Pwidth;
#define Pwidth 35536
#int_TIMER1
void TIMER1_isr(void) {
Output_low(PWMout);
#int_TIMER0
void TIMER0_isr(void) {
Output_high(PWMout);
SET_TIMER1(Pwidth);
main()
ANSEL=11;
setup_adc_ports(AN1_ANALOG);
setup_counters(RTCC_INTERNAL,RTCC_DIV_64);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
setup_vref(FALSE);
enable_interrupts(global);
SET_TIMER0(0);
while(true);
Original Post ID: 144516840
Neutone
Re: PWM on 12f675
PostPosted: Fri Aug 08, 2003 1:56 pm     Reply with quote
:=I am trying to use timer0 and timer1 interrupts to generate a PWM signal on pin_A2. I used 3.169 and the wizard. My non working code follows:
:=#include <12F675.h>
:=#device adc=10
:=#use delay(clock=4000000)
:=#fuses INTRC, MCLR, BROWNOUT, NOWDT
:=#rom 0x3FF = {0x3470}
:=#define PWMout PIN_A2
:=#byte ANSEL=0x9f
:=int16 Pwidth;
:=#define Pwidth 35536
:=#int_TIMER1
:=void TIMER1_isr(void) {
:= Output_low(PWMout);
:= disable_interrupts(INT_TIMER1);
:=#int_TIMER0
:=void TIMER0_isr(void) {
:= Output_high(PWMout);
:= SET_TIMER1(Pwidth);
:= enable_interrupts(INT_TIMER1);
:=main()
:= ANSEL=11;
:= setup_adc_ports(AN1_ANALOG);
:= setup_adc(ADC_CLOCK_INTERNAL);
:= setup_counters(RTCC_INTERNAL,RTCC_DIV_64);
:= setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
:= setup_comparator(NC_NC_NC_NC);
:= setup_vref(FALSE);
:= enable_interrupts(INT_TIMER0);
:= enable_interrupts(global);
:= SET_TIMER0(0);
:= while(true);
I perform PWM for motor control using this routine and only use the timer to regulate the loop period. I can assign values for on and off time. This is based on a loop that runs at a fixed speed. The bit test can be performed on a lesser bit to make it run faster. You could also run a variation of this code inside an interupt.
if(bit_test (PWM_Counter_lo++, 7))
{ PWM_Counter_lo = 0;
PWM_Counter++;
if(PWM_Cycle)
{ if(PWM_Counter > on_time)
{ PWM_Counter = 0;
PWM_Cycle = 0;
{ if(PWM_Counter > off_time)
{ PWM_Counter = 0;
PWM_Cycle = 1;
Original Post ID: 144516843
