What is checksum ??
arunb
What is checksum ??
PostPosted: Fri Aug 01, 2003 12:35 am     Reply with quote
What is a checksum ?? and what is it used for ???
thanks
arun
Original Post ID: 144516542
Sherpa Doug
Re: What is checksum ??
PostPosted: Fri Aug 01, 2003 7:18 am     Reply with quote
:=Hi,
:=What is a checksum ?? and what is it used for ???
:=thanks
:=arun
In its simplest form it is the sum of all the preceeding data, usually modulo 1 byte. There are also other methods more sophisticated then simple summation such as CRC.
The purpose is to check the integrity of the preceeding data. When data is sent from one place to another, such as between computers or between a CPU and RAM, the transmitter can generate a checksum and append it to the data. The receiver then generates its own checksum as the data arrives and compares its checksum with that sent with the data. If the two do not agree there must have been an error in transmission.
To find more do a search on checksum, parity, CRC, and ECC.
Original Post ID: 144516548
