William Guest
| PIC16C774 12-bit ADC |
Posted: Tue Jul 08, 2003 10:28 am |
I am using the PIC16C774's built in ADC. I assign the read_adc() value to 16 bit unsigned value. The numbers I am getting are greater than 2^12, which is the resolution of the ADC. It seems the values are on the range of 2^16. Does the compiler shift the bits left after the read? Any suggestions?
Below is a snapshot of the ADC code.
#include <16C774.h>
#device ADC=12
typedef long uint16;
uint16 rateOut = 0;
setup_adc_ports(ALL_ANALOG|VSS_VDD);
set_adc_channel(0);
rateOut = read_adc();
printf("Gyro = \%lu \r\n", rateOut);
Thanks...
___________________________
Original Post ID: 144515791 |
| Re: PIC16C774 12-bit ADC |
Posted: Tue Jul 08, 2003 11:37 am |
:=I am using the PIC16C774's built in ADC. I assign the read_adc() value to 16 bit unsigned value. The numbers I am getting are greater than 2^12, which is the resolution of the ADC. It seems the values are on the range of 2^16. Does the compiler shift the bits left after the read? Any suggestions?
It's controlled by the ADFM bit. This post tells how to fix it:
<a href="http://www.pic-c.com/forum/general/posts/12580.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/12580.html</a>
Original Post ID: 144515793 |
R.J.Hamlett Guest
Posted: Tue Jul 08, 2003 12:14 pm |
:=Below is a snapshot of the ADC code.
:=#include <16C774.h>
:=#device ADC=12
:=typedef long uint16;
:=uint16 rateOut = 0;
:=setup_adc_ports(ALL_ANALOG|VSS_VDD);
:=setup_adc(ADC_CLOCK_INTERNAL);
:=set_adc_channel(0);
:=rateOut = read_adc();
:=printf("Gyro = \%lu \r\n", rateOut);
:=Thanks...
PCM programmer has answered this, but I have to make one other comment. You need a time delay, between selecting an adc channel, and reading it. The input signal has to charge the capacitance represented by the input, so the delay needed depends on the impedance of the source, and the accuracy you require. Typically something in the order of about 10uSec, is needed with a reasonably low source impedance. Otherwise your actual 'accuracy', will fall well below the adc's resolution...
Original Post ID: 144515794 |
