vsprintf: available in ccs?
darkeagle
PostPosted: Fri May 07, 2010 7:10 am     Reply with quote
As the object, is the vsprintf available in ccs compiler?
d
PostPosted: Fri May 07, 2010 1:17 pm     Reply with quote
Not specifically. CCS has sprintf. In this link they say they support
variable argument lists, but I've never tried it, and don't know if it works.
http://www.ccsinfo.com/content.php?page=varpara
pippo1234
PostPosted: Fri May 07, 2010 4:03 pm     Reply with quote
Tested the sprintf with variable parameters but it does not work.
I think is necessary to write a vsprinft from scratch.
Anyone know a workaround?
P
bkamen
PostPosted: Fri May 07, 2010 5:46 pm     Reply with quote
There's a typo in the sample at that link, but I got it to compile..
Just didn't run it.
-Ben
allenhuffman
PostPosted: Tue Oct 20, 2026 8:38 am     Reply with quote
I ran into a use for this today, and ended up here. Can confirm no vargs support in sprintf.
I have a bunch of places where I populate a buffer that will be returned in a "get debug data" message, and was hoping to make them more clever.
// Log what happened.
char buffer[80];
sprintf (buffer, "%d current %f > %u",
    index, current, currentLimit);
populateDebugDataBuffer (buffer, sizeof(buffer));
Ah well... what's a few more bytes between friends.
Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
Embedded C, Arduino, MSP430, ESP8266/32, and PIC24 programmer.
http://www.whywouldyouwanttodothat.com ?
Using: 24FJ256GA106, 24EP256GP202, 24FJ64GA002 and 24FJ1024GA606.
PostPosted: Tue Oct 20, 2026 12:05 pm     Reply with quote
CCS does support variable argument lists, but the problem with printf,
is that it doesn't have support built in for the format string to handle this.
So extend the number of arguments, and the argument string runs out,
and the code doesn't work.
If you are using a constant format for each item, you can make it work
by having your own function accepting the variable argument list, and
having this pass the arguments one by one to a standard printf, with a
single format string. This does work. You can generate this as a macro
and your own function, to make it behave like vsprintf.
allenhuffman
PostPosted: Tue Oct 20, 2026 2:47 pm     Reply with quote
Yeah, a robot suggested using a macro. Seems like a good approach. This was for logging arbitrary debug strings that could have just text, or any number of variables printed in them. I was just trying to prevent having that buffer and sprintf() each time. ;-)
PostPosted: Thu Oct 22, 2026 12:28 am     Reply with quote
Yes.
The reason this is 'difficult' in CCS, comes down to how the format strings
are handled. On most processors, the format handling is a program in
ROM, that scans the format string and parses this to handle the output.
In CCS, historically the compiler parses the format string at compile time
and then generates the code to handle each format. This saved RAM
massively, and on the original PIC's was really the only practical way of
doing this, It is perhaps sad that CCS haven't offered the traditional scan
behaviour as an option on the later PIC's. Certainly on the larger PIC18's
and even more on the PIC24/30/33, it'd really be the better way to go.
