Hello
I have an old program that I need to modify. The original was compiled with V4.128 (PCWHD). The problem is that the compiler has started giving me an "Option invalid No PLL option" on the #use delay line:
I suspect that the problem may be have been caused when I updated the other version I have installed (V5.082) to V5.124. I did try uninstalling both version and re-installing just V4.128 but I still got the same error. I need to use V4.128 as the old code does not work correctly with the newer compiler.
