Does CCS Compiler support PIC24FJ with dual partition?
E_Blue
PostPosted: Thu Jul 23, 2026 8:43 pm     Reply with quote
I want to develop a device with FOTA support and would like to know if there's any support by CCS Compiler to use the dual partition system in some PICs.
I have v5.091 of CCS Compiler.
The device I'm trying to use is a PIC24FJ1024GB606.
Any info about this will be appreciated.
Electric Blue
asmallri
PostPosted: Fri Jul 24, 2026 12:14 am     Reply with quote
Not specifically what you ask for however...
I'm assuming you are asking this question as you would like to operate this PIC in dual partition modes (2 * 512k) partitions. In this configuration the partitions are essentially ships-in-the-night with neither being aware of the other with the exception that there is some basic setup required of the FBOOT, BTSWP bit and the FTBSEQ numbers.
One consideration for this mode is you basically have to have a copy of the bootloader in each partition. It also implies the bootloaders need their configuration in sync especially in an xOTA configuration with the 'A" meaning Air.
The easiest way to do this is to include the bootloader file in the application. This is the typical way you see it being done in examples of using the CCS supplied bootloaders.
I have been building and supplying bootloaders for PICs for private and commercial customers for years and the approach of embedding the bootloader within the application image is something I personally would not do with the exception of the production golden image.
In 20 years of deploying and supporting bootloaders in the field, I have only needed to upgrade a bootloader in the field update across a customer's network once and that was due to changing network protocols that occurred years after the original field deployment. Bootloader and specifically the flash memory they occupy should not be erased and reprogrammed just because you are updating the application.
The main issue with the dual boot mode flash configuration with the PIC24FJ1024GB606 MCU is the inability to get the device to boot to the other partition in the event of a failure in the active partition. For example, if the application code in the active partition has a problem that causes it to remain in a loop, there is no mechanism to enable the MCU to swap to the other partition. A WDT reset does not help as the MCU will reboot into the same problem partition. This MCU does not a multi-strike auto-rollback register flag and therefore the bootloader, before passing control to the application, is not able to detect that the application has repeatedly reset from a WDT trigger to the processor so the bootloader boots to the problem partition and you have an endless loop.
This means there is no real advantage of using a dual boot mode flash configuration with this MCU as it adds complexity with little benefit. Ultimately for reliability, both types of bootloaders need to maintain some form of external status information for them to remain in bootloader mode when the bootloader detects the continuous reboot problem.
If you are still in the early stages of design, you might want to consider a PIC24 that supports dual boot and supports the multi-strike auto-rollback register flag thus enabling the bootloader to detect the fault and have the bootloader initialise the active partition swap.
Regards, Andrew
E_Blue
PostPosted: Sat Jul 25, 2026 3:31 pm     Reply with quote
Thanks for the detailed information. You’ve given me several things to consider, especially regarding the lack of an automatic rollback mechanism and the implications of using the dual-partition configuration.
My current approach is to implement the FOTA functionality within the application itself, since the device already has to manage the modem and the communication required to download the firmware. I’m still evaluating the best architecture for the dual-partition mechanism, so your comments have been very useful in that regard.
I appreciate you taking the time to share your experience and insights. Thanks again!
Electric Blue
PostPosted: Mon Jul 27, 2026 1:01 am     Reply with quote
The one place where the dual partition can help, is allowing you to have
more sophisticated loader code, which is run while the system keeps
operating.
The default behaviour on boot is that it will boot whichever partition has
the newer ID. You can also program while the code is still executing in
the other partition (provided the protection is setup to allow cross partition
programming). So what you can do is have the executing partition program
the other, _and check that the code is valid_, before setting the ID. Then on
the next reboot, the new code will be executed.
It sounds as if this may be what you are thinking of doing. Remember though,
that the loader code should really always be separate from the main code,
otherwise a single fault in the new code, will then prevent you being able to
recover....
PostPosted: Tue Jul 28, 2026 5:16 am     Reply with quote
curious ...
wonder if it's possible to have some code in 'main' than when it goes 'walkabout' or 'hung' or stops, the PIC would run the other program ??
some kind of failsafe to run the 'backup' program ?
asmallri
PostPosted: Wed Jul 29, 2026 2:55 am     Reply with quote
the newer ID...
The PIC has no cconcept of newer ID. It will booot the sement with Lowest BSEG value irresective of how the relative age of the BSEG value of the respective partition.
The approach outlined will still not solve the problem of the appliction being locked in a loop as a conseqence of some unexpected event that was unforseen by the developer. It does allow a better outcome for the scenario where the bootloader deteects a corruption of the source image file and therefore continues operaating with the current image.
Regards, Andrew
