Using a Crystal just for Timer1
Goto page 1, 2  Next
SkeeterHawk
PostPosted: Thu Jul 16, 2026 12:35 pm     Reply with quote
Hello Friends,
I want to make sure that I am on the right track, so I would appreciate your input.
What I want to do is simple. I have a PIC18F57Q84 that I would like to have an accurate timer on so that I can count every 10mS with only a small amount of deviation in about 15 minutes or so. After doing some research, it appears that Timer1 is the one to use. To use the internal oscillator for the system clock, and only use the crystal on Timer1, is this how I would configure it?
Drop crystal across RA6 & RA7
#FUSES  XT  //  Enable the crystal
#use delay(internal=64Mhz)  //  Set the system clock to use the internal 64MHz clock
SETUP_TIMER_1(T1_EXTOSC)
#INT_TIMER1
void  TenMSTimer_isr (void)
   set_timer1(0xD8F0);   //  65536 - 10000
Is that basically what I would have to do? Thanks so much for the input!! I've already told my customer that I can do this, so I want to make sure that I don't make a mistake. Thanks again for the feedback!
Jonathan
Life is too short to only write code in assembly...
PostPosted: Thu Jul 16, 2026 4:47 pm     Reply with quote
I had a very quik look at the data sheet....
don't see how you can 'just add a crystal as the ext clk to timer 1
1st it's a PPS PIC....
2nd no 'clk osc' section ahead of the timer1 input.
I suggest using a real crystal+2 caps for the main PIC clock, then using it as the input to timer1
This gives you a very stable 'main clock' so ALL PIC timings will be accurate, doesn't cost any 'real estate' either !
Others that use that PIC , or family will know more than my 'gut'.
SkeeterHawk
PostPosted: Thu Jul 16, 2026 7:57 pm     Reply with quote
Thank you very much for interjecting, Temtronic!
I must admit that I "cheated" at the onset and asked AI this question. Here are my thoughts, and is why I am asking you more experienced developers on here to make sure that I am on the right track.
In my datasheet for the PIC18F57Q84 (DS40002213F) it has Timer 1 as chapter 25. In the initial bullet points (P.405), the second bullet says
Programmable internal or external clock source
On page 406, it says to
See TxCLK for clock source selections
and this brings you to table 25-4 on P416. Selection 01000 call out for Timer1 to use the "EXTOSC", but that is under the column Timer3...but I don't think that it is actually for Timer3. Instead, I think that it is saying that at register address 0x321, that addresses Timer1 and writing 01000 to that register should use the external crystal. Table 24.14 on page 420 (Registry Summary) seems to confirm this theory.
I would be surprised if you could reassign the oscillator using PPS because of the impedance issues with a crystal. The PPS table only says that RA6 & RA7 are UART3 CTS and UART3 Rx respectively...which are both inputs.
It is interesting to note that figure 12-1 on page 207 shows the clock sources. It shows CLKIN/OSC1 and CLKOUT/OSC2 as going through the PLLEN as going "to peripherals". It also shows the SOSCI & SOSCO as going "to peripherals" along with the LFINTOSC. Looking at the description for register OSCEN in table 12.5.8 on page 231 says that bit 0 PLLEN just selects whether the PLL is used to boost the EXTOSC by four, but it appears to be available to the peripherals regardless. Additionally, in the same table bit 7 is EXTOEN which is clear by default and it says
EXTOSC can be enabled by a peripheral request
. I think that if I assign the NOSC bits in table 12-2 on page 215 to "110", I will be using the HFINTOSC for the system clock, and my peripheral (Timer1) should be able to use the EXTOSC.
As you look for other EXTOSC reference in the data sheet, it appears that you can assign the EXTOSC to be the clock for just about anything...like UARTS, etc.
PostPosted: Fri Jul 17, 2026 1:28 am     Reply with quote
You can do this.
First thing though is that the XT fuse is not wanted.
What you do is use the secondary oscillator. This chip offers routing this
to other peripherals (on most chips it'll only go to Timer1 by default).
You need the fuse RSTOSC_SOSC which enables the secondary oscillator.
This is then routed to Timer1 using T1_SOSC in the timer1 setup.
This oscillator uses the SOSCI and SOSCO pins that are not remappable.
Pins RC0 and RC1. You cannot put these on RA6/7,
The SOSC pins are special. Offering very low power operation and a low drive
for a 32KHz crystal.
You could do it using an external oscillator, then your EXTOSC setting would
be right, but you would need an oscillator module not just a crystal.
SkeeterHawk
PostPosted: Fri Jul 17, 2026 12:09 pm     Reply with quote
Thank you very much for your input, as always, Ttelmah!
I was planning to use a 4MHz crystal (Sorry I didn't mention that detail in my original post), and I was under the impression that the SOSC could only power a 32.768kHz crystal and I wouldn't be able to get an accurate 10mS tick from that frequency.
I can use an oscillator module if that is my option. I would rather keep this counter internal to the chip than trying to find a real time clock that will give me 10mS ticks since this is a pretty straight forward application. I'd prefer not to add a bunch of bus traffic to my timing because the timing is critical on this application.
Is it true that I can't run a 4MHz crystal on either the SOSC or the EXTOSC and route it to Timer1, would I be running an external oscillator to SOSCIN (RC1) or to CLKIN (RA7)? I am assuming that it is RA7 since you said to keep the EXTOSC. So, if I am required to use an external oscillator, I am thinking that CB3-3C-4M000000 from CTS (Digi-Key P/N 110-CB3-3C-4M000000CT-ND) would be a good choice.
The goal here is to have a really accurate timer that counts 100 "ticks" a second and is accurate to at least 15 minutes, but preferably to 30 minutes. I want to have this as an internal timer so I can clear the counter and start the timer counting at exactly the same time as I toggle an I/O pin. If it is better to use another timer and possibly an external trigger source, that would be good too (Like TOCKI/T0CKIPPS on Timer0). I don't really care how it gets done as long as it is accurate.
Thanks so much for your input to make sure that this application works out of the box!!
PostPosted: Fri Jul 17, 2026 12:55 pm     Reply with quote
Yes, the secondary oscillator can only power a 32KHz crystal.
Why would you want to use 4MHz????
Uses more power, and generally will not be as accurate. The 'point' about
the 32KHz crystals is that they are a different cut from standard crystals
that offers better temperature stability and accuracy, without having to
go to things like TCXO's. Hence for 'timers' they are the preferred crystal.
gaugeguy
PostPosted: Fri Jul 17, 2026 1:33 pm     Reply with quote
If you need a 10ms interrupt then a 32kHz crystal will not work well.
You have not stated what your definition of accurate is. Crystal accuracy is usually given in parts per million (ppm) and temperature deviation in ppm/'C
Accurate over 15 minutes does not really give a definition of what the level of error tolerated would be.
gaugeguy
PostPosted: Fri Jul 17, 2026 1:48 pm     Reply with quote
Also instead of loading timer1 in the interrupt it will be more accurate to use the compare function and update the compare value in the interrupt (add the number of counts you want to the current compare value). That way the timer is free running. When writing the timer in the interrupt you need to figure in the interrupt latency and time to execute the write as well.
PostPosted: Fri Jul 17, 2026 1:49 pm     Reply with quote
OK, I/m curious..
Why not use the 4MHz xtal as your primary clock, then connect Timer1 to it 'somehow' ?
This will give you very accurate timing for the entire program.
SkeeterHawk
PostPosted: Fri Jul 17, 2026 5:07 pm     Reply with quote
I was planning to use the 4MHz osccillator because if I used it as a crystal, the "instruction clock" would already be 1MHz (fosc/4) which would easy to derive an accurate 10mS tick
Ttelmah wrote:
The 'point' about the 32KHz crystals is that they are a different cut from standard crystals
Yes, I totally get it. I have used the 32.768kHz crystals in a number of applications, but this customer wants an accurate timer in 1/100th of a second.
Thank you. That was what I discovered as well when I started looking into the requirements of this project
That is a good question. I was shooting to be the "best it could be", but in reality, it would start to become an issue if I lost or gained a second in 30 minutes. The oscillator that I mentioned earlier has a 50ppm frequency stability. That is 0.005% stability. In 30 minutes, there are 1800 seconds, which would be a deviation of 0.09 seconds. Since that is <100mS (0.1S), that should be sufficient. This application could probably tolerate 100ppm of frequency deviation before it started causing problems. All this said, I think that ultimately there will be a PC that will read my clock (tick count) within a second or so after I send my start signal to the other system that we are synchronizing with, but I want to maintain accuracy in case the PC application experiences latency and needs to read my clock later on.
That is a very good suggestion. Thank you! I will look into doing that. I still need to make sure that the hardware is hooked up correctly as I will be turning this board within the next few weeks.
temtronic wrote:
OK, I/m curious..
Unfortunately, I need to run this processor clock about as fast as I can because its primary function is to be a hub of communications. This clock is a specification that I was just made aware of, so I need to incorporate it into an already functioning system. I was already having issues that caused me to have to crank the clock up to 64MHz, and that worked and that was just coming up from 32MHz. The application won't work at 4MHz for sure. I don't think that it would even work on a 40MHz crystal and using the 1:4 prescaler to get a 10MHz clock for the timer. The only timer that I need to be accurate is for this 10mS tick...everything else just has to be fast.
PostPosted: Sat Jul 18, 2026 5:17 am     Reply with quote
hmm, guess I wrote it wrong.... I meant to say use the 4MHz xtal ,but configure the 'primary clock section' to run at 64MHz. Some combination of PLL may allow that ? Might nee a faster xtal...have to ,ugh, read, the databook to see if it's possible.
My real point is to use a xtal as the 'main' clock' ,as it'll provide better timing for everything.
edit.... looked at the 'clock' internals.....
if you use a 16 MHz xtal and X4 PLL, you'll get a solid 64 MHz clock....
PostPosted: Sun Jul 19, 2026 10:25 am     Reply with quote
Yes. That would be the standard way to do this.
16MHz crystal. 4*PLL. Run the peripherals either off Fosc, or Fosc/4.
If you select the latter, you then can use the /8 prescaler, and then use /5000
to give a timer that interrupts every 10mSec.
SkeeterHawk
PostPosted: Sun Jul 19, 2026 3:47 pm     Reply with quote
That was a fantastic suggestion, temtronic!!! I don't know why I hadn't considered that. That is what makes this forum such a valuable resource!
Thank you for expounding on this methodology, Ttelmah!! That totally makes sense, and your insight is GREATLY appreciated!!!
I will also see if I can incorporate @gaugeguy's suggestion of using the compare function to further imporve accuracy.
Thank you all for the extremely helpful suggestions!!! Very Happy
asmallri
PostPosted: Sat Aug 01, 2026 6:57 pm     Reply with quote
So... It is easier to generate 1ms interrupts that 10ms interrupts. What are you actualy doing in the interrupt handler and how does the interrupt handler interact with the mainline?
Regards, Andrew
PostPosted: Tue Aug 04, 2026 3:17 pm     Reply with quote
one possible 'cheat' is to use an external RTC module. I've done this for ,sigh, decades,using it for a 1 second 'heartbeat', to update the LCD modules, trigger DS temperature sensors.
The newer RTCs are very accurate compared to the original DS1307s.
Goto page 1, 2  Next
Page 1 of 2
