TLS library that will work on PIC24FJ1024GA606? Wiznet 5500
allenhuffman
PostPosted: Mon Jun 22, 2026 4:02 pm     Reply with quote
Mbed TLS is highly recommended, but it requires 32-bit ints.
WolfSSL is highly recommended, but it requires a $7500 commercial license.
BearSSL is both highly recommended and highly discouraged -- and still in beta -- but it might work on 16-bit int systems.
Are there any PIC24-friendly TLS options???
We have a new hardware platform I have added http and such to, but we need to support encryption to send e-mail. This has led me down a bunch of routes that all dead end.
Embedded C, Arduino, MSP430, ESP8266/32, and PIC24 programmer.
Using: 24FJ256GA106, 24EP256GP202, 24FJ64GA002 and 24FJ1024GA606.
PostPosted: Tue Jun 23, 2026 12:47 am     Reply with quote
Wolf is the only library I know that works on the PIC24.
Have you considered adding a hardware SSL chip?. There are a couple of
I2C ones that easily do the 'heavy lifting' of this.
Seriously this is a huge amount of processing work, and is not really suited
for smaller processors. It can be made to work (The Wolf code shows this),
but it still uses a huge amount of code space and processor time. It'd
probably be cheaper and easier, just to move to a smaller PIC, and add an
external chip to handle this. Search for TRUST&GO and TRUSTFLEX. There
are three chips I know of that could be used.
You would be looking at running out of RAM and ROM if you want to do a
lot 'else' on the processor.
allenhuffman
PostPosted: Tue Jun 23, 2026 9:19 am     Reply with quote
I can only use the hardware I have available. But if they have to do a board spin, they might be able to swap to a PIC32 then we could use Mbed TLS.
PostPosted: Thu Jun 25, 2026 12:01 pm     Reply with quote
Worth saying, that in fact the other libraries will probably work, but the
problem is just how slow they will be, and the sheer size.
allenhuffman
PostPosted: Thu Jun 25, 2026 12:02 pm     Reply with quote
In our case, we just want to be able to send an email notification. Whether that takes 1 second or 30 likely doesn't matter.
