AlastairM
| dsPIC UART error recovery |
Posted: Wed Mar 04, 2026 3:41 am |
dsPIC33CH128MP202 dual core (this code is on the master)
compiler 5.123
sorry! code rather complex so here are the relevant bits snipped out:
#include <33CH128MP202.h>
#use delay(internal=20MHz)
#define MODBUS_SERIAL_RX_PIN PIN_B15
#define MODBUS_SERIAL_TX_PIN PIN_B14
#define MODBUS_SERIAL_BAUD 9600
#define MODBUS_SERIAL_STOP_BITS 1
#define MODBUS_PARITY "NONE"
#pin_select U1TX=MODBUS_SERIAL_TX_PIN
#pin_select U1RX=MODBUS_SERIAL_RX_PIN
#use rs232(baud=MODBUS_SERIAL_BAUD, UART1, bits=8, stop=MODBUS_SERIAL_STOP_BITS, parity=N, stream=MODBUS_SERIAL, errors) |
The incoming data is read in interrupt INT_RDA and works perfectly for hours of testing. Unless the power is cycled and occasionally the UART dies!
The Modbus serial port is connected to a WiFi module which at power turn on sends some debug info to the PIC which, I think, occasionally kills the UART (completely fixed by a _MCLR_ reset)
My workaround is to delay the WiFi module from sending serial data at turn on and minimise the data sent.
But my main query is why isn't the UART1 error state fixed by a getc() like it should be with ERRORS switch utilised in the #USE RS232?
Are there any other ways the UART1 can be temporarily killed? (there is a second UART for debug so I can see that the program is running as intended but the INT_RDA isn't triggered. (I can see incoming data on the 'scope)
What error bits / debugging would be best to test my hypothesis of why it's not working? - I've run out of ideas!
Alastair |
Posted: Wed Mar 04, 2026 5:23 pm |
It's been a while since I looked into the issue of UART error conditions and a great deal has been lost to the fog of time but I do remember that in the end I was grateful that CCS will handle these things for me. From what I recall clearing UART error conditions wasn't as straightforward as I thought it was but the processor's data sheet will help guide you.
Have you read the relevant UART status/control registers and examined/printed them when running normally and when the lockup occurs? I've downloaded the data sheet for the processor and there are a number of bits in various registers that seem to be asserted when various error conditions arise. If you know the specific errors, clearing them should be rather straightforward.
The most straightforward brute force approach would be to use the processor's PMD (peripheral module disable) to kill the UART's power entirely, then re-enable and reconfigure it. I'd consider this to be your last resort though; you should be able to monitor the UART's status registers and be able to remedy the problem without resorting to this extreme. Indeed, your observation that a /MCLR reset restores operation would point toward a register somehow getting loaded with an incorrect value under certain hard to duplicate conditions. |
AlastairM
Posted: Wed Mar 04, 2026 6:05 pm |
Hi, thanks for the reply.
I should probably just stop the external module from streaming data so soon after turn on but it's easier to clear the error at the dsPIC end for now...
When the fault occurs FERR and OERR are set in U1STA (23C).
OERR, I think, is the flag which means the UART has stalled.
as a quick fix I look for OERR to be set and then in the main loop read characters until it clears. Once cleared the interrupt fires again and everything works as expected
if(OERR)
fprintf(MASTER_RS232,"\r\nError!");
while(kbhit(MODBUS_SERIAL))
fgetc(MODBUS_SERIAL);
fprintf(MASTER_RS232,"\r\nClearing error!");
delay_ms(200);
It must be a race condition as the #USE RS232 command sets up the UART while characters are being received from the external WiFi module and kills it before the Rx interrupt is set up and able to read the characters. After this point the interrupt doesn't fire and fgetc() in the interrupt routine doesn't get called and so can't clear the fault.
The above code reads 7 times and then everything works again. I think the buffer is 4 deep so I'm not sure why it reads so many times (the WiFi module is idle at this point) |
gaugeguy
Posted: Thu Mar 05, 2026 10:19 am |
| In your INT_RDA routine, make sure you keep checking for data until the FIFO buffer is empty. |
Posted: Fri Mar 06, 2026 2:30 am |
The UART on the PIC24/30/33, can be a bit more complex than the older
PIC's. The 'ERRORS' flag does not catch and recover properly from all
errors. I use the hardware interrupt recovery on the UART's for 100%
reliability. As has been pointed out by another poster, your interrupt
handler must read all the characters in the buffer. So loop as Alastair is
showing inside the interrupt handler to get them all. If you read
only one character, and exit the handler, if another arrives between the read
and the exit of the handler, the IRQ will not be set again. On the more basic
PIC's the IRQ will set whenever a character is present to be read. On the
16bit PIC's it is only set when a character is added to the buffer. Since the
exit from the IRQ clears the IRQ, if you only read one character the buffer
will slowly fill up.
I suspect this is the main problem,
For error handling:
#bit OERR1=getenv("bit:OERR")
#bit FERR1=getenv("bit:FERR")
#bit PERR1=getenv("bit:PERR")
#word U1RXREG=getenv("SFR:U1RXREG")
#bit OERR2=getenv("bit:OERR")
#bit FERR2=getenv("bit:FERR")
#bit PERR2=getenv("bit:PERR")
#word U2RXREG=getenv("SFR:U2RXREG")
//Add more for other UART's if required.
#define CAT(x,y) x##y
#define CAT3(x,y,z) x##y##z
#define HASH_LIT #
#define HASH() HASH_LIT
#define EFUNCTION(x) void CAT(errorint, x) (void) { \
static int16 eword; \
if (CAT(OERR,x)) { CAT(OERR,x) = 0; return; } \
if (CAT(PERR,x)) { eword=CAT3(U,x,RXREG); } \
if (CAT(FERR,x)) { eword=CAT3(U,x,RXREG); } \
#INT_UART1E
EFUNCTION(1)
#INT_UART2E
EFUNCTION(2)
//Then at the start of your main code, when you are launching the
//UART's
//enable error handlers first
enable_interrupts(INT_UART1E);
delay_cycles(1);
enable_interrupts(INT_UART2E);
delay_cycles(1);
//The NOP's allow the handlers to be called if there are any errors
//set.
enable_interrupts(INT_RDA); //serial interrupt
enable_interrupts(INT_RDA2); //second serial
The natural interrupt priority on the chip ensures the error interrupt
will always be called before the normal interrupt handler. The efunction
code here turns off the error bits, leaving the standard handler to then read
the byte. |
