allenhuffman
Joined: 17 Jun 2019 Posts: 681 Location: Des Moines, Iowa, USA
| PIC24 interrupts - clear_interrupt() from inside an ISR? |
Posted: Sat Feb 28, 2026 10:56 pm |
To paraphrase... "When everything is the highest priority, nothing is the highest priority."
We use I2C for messages between our PIC24-based boards and a PC host program. We use the I2C interrupt to process a write or read from the PC master. This works well.
Recently, I updated firmware on a board which added new hardware to trigger a pin during a PWM pulse on an RF detector. The pins (two detectors) get mapped to the Change Notification Interrupt (INT_CNI). The interrupt fires on the rising edge and falling edge. Since both detectors normally see the same RF signal, this means four interrupts fire each PWM pulse.
At the 10,000 Hz pulse rate, that could be 40,000 interrupts a second. Since they all go to the same routine, which checks for the high status of the CNI pins... Pseudo code:
| Code: | if input_state (FWD_DET_PIN) || input_state (REF_DET_PIN)
...read the detector via SPI...
If both pins trigger, I believe the CNI is only called once since it is already pending when the second pin goes high. This works well.
But, it does introduce issues if the I2C interrupt is handling an incoming byte, potentially delaying a PWM pulse. As far as I can see, we have enough wiggle room in our pulse that an i2c_read/i2c_write likely is not an issues. (We delay about 20 us to let the signal stabilize, then read, and have almost 20 us left after the SPI read).
But, it seems the PWM delay can sometimes/often throw off the I2C timing so the one byte RBF is full and misses something or -- worse -- at the end of a message we miss capturing the I2C stop bit condition. Without the deadlock check I added years ago, it would hang and the watchdog would reset.
I am experimenting with solutions.
Q1) For example, could I simply do a "clear_interrupt (INT_CNI)" at the end of my I2C handling ISR? We can throw away a pulse and catch the next one.
Side note: my personal solution was to never have the PWM interrupts enabled until we need a reading (we do not need 10,000 readings a second, even if our PIC could keep up with that many). This delays the reading by one pulse which is still more than fast enough. BUT, even doing this, that pulse seems to mess up an I2C thing.
Q2) I am also considering just using the first I2C interrupt, then staying in that loop polling the message bytes, rather than letting other things run in between I2C read/writes. This will slow things down, but a reliable message system is more important (and the PIC is handling the main loop way faster than the PC can hope to poll it over I2C).
I assume many have dealt with multiple "highest priority" interrupts, and wonder what other solutions there might be.
Thanks for any tips. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
Embedded C, Arduino, MSP430, ESP8266/32, and PIC24 programmer.
Using: 24FJ256GA106, 24EP256GP202, 24FJ64GA002 and 24FJ1024GA606. |
Posted: Sun Mar 01, 2026 7:12 am |
Could you reset a timer whenever you enter the CNI interrupt?.
Then have the I2C routine test this timer, and only clear age CNI
interrupt if the time is greater than you would expect since the last PWM
handling event.
If the I2C is higher priority than the PWM, can''t you just lower the
PWM priority one step?. Given there are 8 priority levels you should
still be OK. The PIC24, doesn't just have high/low priority interrupts,
it has multiple priority levels. If both interrupts have the same priority
level, then neither can interrupt the other. If you give them different
levels, you can choose which can interrupt the other. |
allenhuffman
Posted: Sun Mar 01, 2026 12:48 pm |
| Ttelmah wrote: | Could you reset a timer whenever you enter the CNI interrupt?.
handling event.
We had previously enabled NESTED INTERRUPTS on this board for this very reason - so the I2C could always get its work done. I recently had to disable that because if a pulse came in during I2C work, the PWM ISR would be delayed. It could start reading while the pulse was high but then the pulse dropped causing a much lower reading. The workaround is to throw those values away. I am hoping for a non-workaround.
We just implemented a 20 us (technically 20.5) to avoid using a delay_us(), so that might be an option. Actually, I'd be okay with just disabling the PWM IRQ entirely during an I2C transfer since I know if the system is busy processing a message, it's not using the PWM detector sample. Hmmm. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
Posted: Sun Mar 01, 2026 11:38 pm |
PK. So it sounds as if you might have an answer. Disable the PWM
interrupt when you enter the I2C handler, and clear it's IRQ before
re-enabling this at the end of the I2C handler. |
allenhuffman
Posted: Mon Mar 02, 2026 8:00 pm |
Sadly, even disabling all interrupts other than the I2C interrupts did not resolve the issue. Years ago, when I created this code, I added a deadlock detection routine. We can easily get 14+ million messages with zero errors.
Little did I know that the deadlock detection was kicking in, fairly regularly.
I spent all day digging into this with logic analyzers capturing the I2C traffic and I/O pins and debugging output.
It seems sometimes the code misses one of the I2C states. I will see it get the "master is writing" state, then the bytes after the address all are NACKed, then the read shows up, and my routine sees this as an unexpected read.
There are no relevant I2C errata for this chip (though the code does have a workaround for an errata on one of the other PIC24s we use). I plan to do one final test, with a small test program that ONLY does the I2C and an empty main loop and see if it behaves the same.
But the PWM interrupts are what alerted me to the situation, and made it happen much more often, so being able to make those definitely helps.
But now that I see the problem exists, I can't unsee it -- even if my "band-aid" works around it wonderfully ;-) I hope to remove the band-aid. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
asmallri
Joined: 12 Aug 2004 Posts: 1678 Location: Perth, Australia
| Re: PIC24 interrupts - clear_interrupt() from inside an ISR? |
Posted: Tue Mar 03, 2026 6:24 am |
| allenhuffman wrote: | | To paraphrase... "When everything is the highest priority, nothing is the highest priority." |
This may be a red hering so forgive me if it is.
I deveoped a bootloader ages ago that had a Primary PIC that communicated with a PC and a secondary PIC, attached to the primary PIC via I2C. The primary PIC coulld be bootloaded by the PC and, while in botloader mode and when instructed to by the PC, would transparently pass bootloader traffic from the PC to the slave PIC over I2C. It was a proven solution that worked on PIC24 and dsPIC33 variants. The soluion does not use innterrupts (I avoid interrupts in bootloades) and the solution has been widely deployed.
Last year migrated the solution to a different customer's plattform in this case using PIC24s as the master and slave but they were different variants. It should have worked but instead of taking me a a few hours to port the working bootloder system it took me two very frustrating weeks. In the end the problem was due to one of the PICs not implementing it's hardware I2C state machine correcty despite claiming it did in the manual. _________________ Regards, Andrew
Posted: Tue Mar 03, 2026 11:28 pm |
Unfortunately little hidden behaviours seem to be getting more and more
common on the PIC's. I wonder if there is any way of working out which
particular actual I2C state is causing the problem?. Would need some
fairly complex diagnostics. |
