I have an easy one for you: Does ICD-U64 support DSPIC33CK?
robleso7473
PostPosted: Thu Dec 04, 2025 12:00 pm     Reply with quote
Hello CCS support team,
Does the ICD-U64 programmer support the DSPIC33CK MCUs?
SW rev 5.088
FW rev 3.68
HW rev 3 (PID195)
Thank you,
Oscar
dyeatman
PostPosted: Thu Dec 04, 2025 1:29 pm     Reply with quote
Worked fine for me!
I used it with 33CH Dual core (using two ICDU64) and one with the 33CK single core.
robleso7473
PostPosted: Thu Dec 04, 2025 1:33 pm     Reply with quote
You’re quite lucky then. I can program mine with Load-n-Go but will not work with two different ICD-U64’s with the latest FW. What gives?
dyeatman
PostPosted: Thu Dec 04, 2025 1:37 pm     Reply with quote
I think I was using the 66 version rather than 68.
Haven't used 68 yet. You might try one of the earlier versions.
BTW, we are not CCS support, just a bunch of customer/users
robleso7473
PostPosted: Thu Dec 04, 2025 1:38 pm     Reply with quote
Not a bad idea. Let me give that a go.
robleso7473
PostPosted: Thu Dec 04, 2025 1:52 pm     Reply with quote
You did it, Dyeatman!
Thanks to your suggestion to revert back to 3.66 I went back and noticed that each FW revision has two associated upgrades: One for all non-DSPIC targets and one for all + DSPIC targets. I had erroneously chosen the non-DSPIC targets so now wonder it didn't work. Now it works on 3.68.
Your suggestion was quite serendipitous. Thank you again.
Oscar[/img]
dyeatman
PostPosted: Thu Dec 04, 2025 1:55 pm     Reply with quote
Glad I could help!
PostPosted: Fri Dec 05, 2025 4:12 am     Reply with quote
That is a bit of a 'classic'. The U80, has enough memory space that the
firmware is 'universal', but on the U64, there is not quite enough ROM, so
they do the two FW versions. The annoyance is that the U64 seems to be
more reliable in general than the U80 (though this does seem now to
be getting better on the later software releases). I wish they did a U64'2'
with a larger processor.... Very Happy
Just a comment. You started your post with Hello CCS support team.
That is not us!...
We are just CCS users. This is a user forum, _not_ CCS. Read the header
at the top right of the forum pages.
As it turned out, we could answer, but for CCS support, you would need to
email them.
