9g servo control algorithm (PIC16F877A)
Khansokhua
PostPosted: Tue Dec 06, 2022 8:27 pm     Reply with quote
Hi fellas, greetings.
It's been a while since I corresponded with you on the forum. I wonder how can I control 9 g servo with a PIC mc these days. I bought a Pickit3. I earned a new overlook inside my heart:)))
Respects!!!
PostPosted: Tue Dec 06, 2022 9:42 pm     Reply with quote
You really need to post WHICH 'servo' you have.
If I assume '9g' is a brand ?? then you mean a typical RC hobby 'servo', then you simply send a repeating pulse train at 50hz, that is between 1 and 2 ms.1ms is full left, 2ms is full right, updated 50 times a second..
at least that was the standard 3 decades ago
there has to be 100s of CCS c code on the web for this, several mfrs sold chips that controlled 8 or 16 servos .
CCS also supplies a basic RC servo program in the 'examples' folder
you can of course use simple delay_us(xxxx); commands for it , or use a timer...
what type of coding depends on what else you want the PIC to do...
PostPosted: Wed Dec 07, 2022 12:20 am     Reply with quote
9G is a standard term for micro servos. 9 gram. Generally they are
standard servos in terms of driving. The original one was the FS90 and
then the SG90, So your comments are spot on Jay. Also there are quite
a few servo drive codes in the code library.
Khansokhua
Motor
PostPosted: Wed Dec 07, 2022 6:27 am     Reply with quote
It is SG90. First goal is make a continuous movement 0 to 90 and then 90 to-90 then -90 to 90...
PostPosted: Wed Dec 07, 2022 3:23 pm     Reply with quote
wow...
https://www.amazon.ca/Miuzei-Helicopter-Airplane-Remote-Control/dp/B07H85M78M
$3 CDN for a servo !!!
link show the time vs location,pretty easy to understand, even for an old dinosaur like me....who has the Signetics 7 channel decoders in a drawer here.
PostPosted: Thu Dec 08, 2022 7:57 am     Reply with quote
You can even find them cheaper than that.
Some things now are mind blowing in terms of just how little they can be
bought for.
PostPosted: Thu Dec 08, 2022 9:55 am     Reply with quote
I had to lookup what a 5 wire servo was....
sigh....
motor/drive train and pot....
NO electronics.
