pilar
| How to Wake-Up with WDT |
Posted: Tue Jun 14, 2022 10:59 am |
I'm using a PIC18LF4520 and I'm using it with CCS 4.074, I want to use a low power state and for that I send it to sleep and I want to wake it up with the WDT but it seems that it's not working, the pic doesn't wake up, can someone tell me how to solve this ?
| Code: | #include <18F4520.h>
#fuses HS,WDT128,NOPROTECT,NOLVP
main() {
switch ( restart_cause() ) {
case WDT_TIMEOUT: {
printf("\r\nRestarted processor because of watchdog timeout!\r\n");
case NORMAL_POWER_UP: {
printf("\r\nNormal power up!\r\n");
setup_wdt(WDT_ON);
restart_wdt();
SLEEP();
while(TRUE) {
Posted: Tue Jun 14, 2022 11:25 am |
If the 18F4520 is sleeping, a WDT timeout will cause the PIC to wake up
from sleep and continue running code after that point. If the PIC is sleeping,
the WDT will not cause a reset.
This is in the PIC datasheet, in section:
| Quote: | | 3.5.2 EXIT BY WDT TIME-OUT |
pilar
Posted: Tue Jun 14, 2022 11:52 am |
Yes, I read it, but it is not clear to me, what would I have to modify in this code to get what I need, that the pic goes to sleep and that the WDT wakes it up? |
PrinceNai
Posted: Tue Jun 14, 2022 12:15 pm |
Maybe this will do what you want:
main() {
case RESET_INSTRUCTION: {
setup_wdt(WDT_ON);
restart_wdt();
SLEEP();
reset_cpu();
while(TRUE) {
Mind that the code as it is will never reach while(true) loop, so it will basically just keep resetting the CPU. I suppose you want it to do something when the processor wakes up :-) |
Posted: Tue Jun 14, 2022 12:17 pm |
Try something like this:
#fuses HS,WDT512,NOPROTECT,NOLVP, PUT
#use delay(clock=20M)
printf("Start\n\r");
restart_wdt();
sleep();
delay_cycles(1);
printf("Wake-up from sleep occurred\n\r");
restart_wdt();
PrinceNai
Posted: Tue Jun 14, 2022 12:30 pm |
Or if you want something done after wake-up, something like this:
#define Working 1
#define Sleeping 2
int8 Go_To_Sleep = Working;
main() {
setup_wdt(WDT_ON);
restart_wdt();
while(true){
switch (Go_To_Sleep) {
case Sleeping: {
printf("\r\nSleeping!\r\n");
sleep();
case Working: {
printf("\r\n!Working!\r\n");
Go_To_Sleep = Sleeping;
Restart WDT as needed..
pilar
Posted: Tue Jun 14, 2022 5:11 pm |
Thanks everyone, i got what i needed |
PrinceNai
Posted: Tue Jun 14, 2022 7:25 pm |
Nice to hear. For the posterity it would be cool if you posted which answer helped you. So that someone with a similar question can find a solution
Regards,
Samo |
pilar
Posted: Wed Jun 22, 2022 3:30 pm |
Thank you PrinceNai, your code worked for me
| Code: | #fuses HS,WDT128,NOPROTECT,NOLVP
#define Working 1
#define Sleeping 2
main() {
setup_wdt(WDT_ON);
restart_wdt();
while(true){
case Sleeping: {
sleep();
case Working: {
