PIC18F46K22 ADC timer1
Khansokhua
PostPosted: Wed Dec 22, 2021 12:29 pm     Reply with quote
#include <SSSCSC.h>
//!#device ADC=8
#use delay (clock=20000000)
#use fast_io(a)
#use fast_io(c)
#include <HDM64GS12.c>
#include <graphics.c>
#define display_1 pin_B6
#define display_2 pin_B7
#define button pin_A1
#define secme pin_B3
#define slayt pin_A2
const char imagine[]={0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x80, 0xC0, 0xC0, 0xC0, 0xC0, 0xE0, 0xE0, 0xF0,
0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF8, 0xF8, 0xF8, 0xF8, 0xF8, 0xF8, 0xF0, 0xF0, 0xF0,
0xF8, 0xF0, 0xF0, 0xF8, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xE0, 0xE0, 0xE0,
0xE0, 0xE0, 0xE0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xC0, 0xE0, 0xF0, 0xF8,
0xF8, 0xFC, 0x3E, 0x3E, 0x3F, 0x3F, 0x1F, 0x1F, 0x1F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F,
0x0F, 0x0F, 0x07, 0x07, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x1F, 0x0F, 0x1F, 0x1F, 0x1F,
0x1F, 0x1F, 0x1F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F,
0x0F, 0x1F, 0x1F, 0x1F, 0x1F, 0x1F, 0x3F, 0x1F, 0x1F, 0x3F, 0x3F, 0x3E, 0x7E, 0xFE, 0xFC, 0xF8,
0xF8, 0xF0, 0xE0, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0E, 0x3F, 0x7F, 0xFF, 0xFF, 0xFF,
0x3F, 0x0C, 0x00, 0x00, 0x00, 0xC0, 0x40, 0x40, 0x40, 0x60, 0x60, 0x40, 0x60, 0x60, 0x60, 0x60,
0x60, 0x60, 0x60, 0x60, 0xC0, 0xC0, 0xC0, 0x40, 0xC0, 0xC0, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x40, 0x40, 0x60, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0,
0xE0, 0xE0, 0x60, 0x20, 0x60, 0x60, 0x60, 0x60, 0x60, 0x40, 0xC0, 0x80, 0x00, 0x07, 0x07, 0x1F,
0xFF, 0xFF, 0xFF, 0xFF, 0x7F, 0x9E, 0x00, 0x00, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x0D, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x19, 0x0F, 0x03,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x03, 0x03, 0x03, 0x03, 0x01, 0x01, 0x03,
0x03, 0x03, 0x03, 0x01, 0x00, 0x01, 0x01, 0x03, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x01, 0x01, 0x01, 0x00, 0x00, 0x01, 0x03, 0x03, 0x03,
0x01, 0x01, 0x01, 0x03, 0x03, 0x03, 0x03, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x43, 0x07, 0x0D, 0x08, 0x28, 0x10, 0x00, 0x00, 0x00, 0x01, 0x01, 0x06, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x48, 0x68, 0x6A, 0x6A, 0x6E, 0x2C, 0x28, 0x00, 0x54,
0x0C, 0x58, 0x68, 0x6A, 0x6E, 0x6E, 0x68, 0x68, 0x48, 0x48, 0x50, 0x10, 0x10, 0x00, 0x00, 0x00,
0x00, 0x00, 0x80, 0x80, 0x40, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x02, 0x02, 0x03, 0x06, 0x0E, 0x0E, 0x0E,
0x1E, 0x1C, 0x3C, 0x3C, 0x3C, 0x78, 0x78, 0x78, 0x7C, 0x78, 0xF8, 0xF0, 0xE0, 0xF1, 0xE1, 0xE1,
0xE3, 0xE1, 0xF1, 0x71, 0x61, 0x70, 0x68, 0x70, 0x78, 0x78, 0x78, 0x78, 0x38, 0x3C, 0x3C, 0x1E,
0x1E, 0x0E, 0x0E, 0x06, 0x07, 0x02, 0x01, 0x00, 0x01, 0x00, 0x80, 0x70, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x00, 0x40,
0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x80, 0xC0, 0x60, 0x20, 0x30, 0x1C, 0x06, 0x03, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0E, 0x0C,
0x00, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x07, 0x0F, 0x0F, 0x0F, 0x0E, 0x0C,
0x08, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
int a=0;
int i,j,k;
int32 sayac;
#int_timer1
void timer()
   set_timer1(3036);
    a++;
    if(a==10){
    int x=0; //5s and 1.25s
int y=0;
glcd_init(on);
   for(i=0;i<64;i+=8)
         for(j=0;j<128;j++)
            for(k=0;k<8;k++)
               if(bit_test(imagine[sayac],k))
                  glcd_pixel(x+j,y+i+k,ON);
            sayac++;
 sayac=0;
   a=0;
 setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);
 set_timer1(3036);//0.5s tek kesme
 enable_interrupts(int_timer1);
Hi, greetings. I set timer1 for 5 second timing and it works OK. However, when I try to add ADC:
#include <TT.h>
#device ADC=8 // Can not set this option this far into the code
#use delay (clock=4000000)
#use fast_io(a)
I receive an error. Then I change .h file name into 18F46K22.
#include <18F46k22.h>
#device ADC=8
This time there is no error but timer1 responds after 1.25s (a==10). So here I am confused. Thanks.
Respects...
PostPosted: Wed Dec 22, 2021 4:03 pm     Reply with quote
It takes 842 ms to run this loop (with a 4 MHz PIC clock):
for(i=0;i<64;i+=8)
         for(j=0;j<128;j++)
            for(k=0;k<8;k++)
            sayac++;
#include <TT.h>
#use fast_io(a)
Put that line inside the TT.h file. Put it immediately after the
#include file for your PIC.
Khansokhua
PostPosted: Wed Dec 22, 2021 5:35 pm     Reply with quote
Thank you sir, it worked.
