jychua
| #rom crc16(start, end) Access Violation |
Posted: Wed Nov 10, 2021 10:45 am |
Using PCWHD Compiler (IDE version 5.105 and PCH version 5.105), I am trying to use the #rom macro to put CRC calculation within the program memory. But for some reason the crc16 option is giving me a violation error.
The checksum option works fine:
| Code: | | #rom 0xFFFE = checksum |
However, neither crc16 nor crc16(start, end) works for me:
#rom 0xFFFE = crc16
#rom 0xFFFE = crc16(0x002000, 0x00FFEF)
The error/info I get for those options is "Access violation at address 060A7644 in module 'PCH.dll'. Write of address 00002000" and "Internal Error - Contact CCS OUTPUT FILE .sym".
Based on the description, it would seem I have to contact CCS support. I was wondering if anyone here happen to have encountered and resolved the same issue?
Thanks! |
Posted: Wed Nov 10, 2021 11:01 am |
Critical extra bits of data:
What chip?.
Post the fuses. |
jychua
Posted: Wed Nov 10, 2021 12:09 pm |
Hey Ttelmah,
Sorry my bad. Target is PIC18F46Q10. Fuses are as follows:
#fuses NOPPS1WAY, BROWNOUT, BORV28
#fuses NOLVP, WDT_SW, PUT
#fuses SCANE
#fuses NOPROTECT, NOCPD
#use delay(CLOCK=OSCILLATOR, internal=8M)
Thanks! |
Posted: Thu Nov 11, 2021 4:03 am |
It is a compiler fault.
Seems to be doing the same for several compiler versions, and for different
chips.
You need to talk to CCS... |
jychua
Posted: Thu Nov 11, 2021 8:07 am |
Thanks for looking into this! Will do.
Best,
jychua |
