Khansokhua
| CCS C Compiler PIC16F877A - To run Simultaneously |
Posted: Tue Nov 09, 2021 4:30 am |
Greetings.I would like to ask if anyone give me any suggestion.I would be glad. Here's the question:
"While all led on PortB is being on in turn. Pin "B5" will be on and 3-9 counter will start run on PortD. However, the leds will continue run on its way with 7 segment display on PortB simultaneously.
(B0-B1-B2-B3-B4-B5-B6-B7-B0-B1-B2-B3-B4-B5-B6-B7-...)
( 3 - 4 - 5 - 6 - 7 - 8 - 9 3 - 4 - 5 -...)
I tried something but I couldn't find any available algorithm.
signed int i,j;
const int segment[7]={0x4F,0x66,0x6D,0x7C,0x07,0x7F,0x6F};
const int led[8]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
set_tris_b(0x00);
output_b(0x00);
output_a(0x02);
for(i=0;i<=7;i++)
output_b(led[i]);
delay_ms(250);
if(i==5)
for(i=0,j=6; (i<=7 && j==7) ;i++,j++)
delay_ms(250);
output_d(segment[i]);
output_b(led[j]);
i=-1;
Posted: Tue Nov 09, 2021 7:55 am |
If you want the two things to happen simultaneously, then do them in the
same loop:
signed int i,j;
// set_tris_b(0x00);
Unless you are using fast_io, don't fiddle with TRIS.
output_b(0x00);
output_a(0x02);
for(i=0;i<=7;i++)
output_b(led[i]);
delay_ms(250);
If you want the two things to happen at different rates, then instead of the
basic loop, use a 'state machine'. Have a single delay, and a single counter,
but have it counting to a much larger number. Then (say) on each loop do
one of the operations, while on every fourth loop do the other, Then the
two things will be simultaneous, but one will be at 1/4 the speed of the
other. Make the count needed to do the second operation, suit whatever
rate you want relative to the first. |
Posted: Tue Nov 09, 2021 12:25 pm |
Another recent addition to the compiler is that you can also use event driven programming (versus a state machine) so if you are a using a compiler from the last 1.5 years or so, you can use the "timeouts" library to have events occur at various rates:
https://www.ccsinfo.com/newsdesk_info.php?newsPath=ALL&newsdesk_id=214
There's a much more thorough example in the Examples subdirectory of your compiler's installation directory. |
Khansokhua
Posted: Tue Nov 09, 2021 1:33 pm |
I am a new learner.
Can you send me lots of examples that I will be able to apply, various way to do.Easiest one to complex one...
I am unfamiliar to these terms right now. |
PrinceNai
Posted: Tue Nov 09, 2021 3:03 pm |
First please understand that NOTHING on a PIC is done simultaneously. It is just a sequence of instructions, and they all take time. Because of the speed of those instructions being executed we feel that different things are done at the same time. At least that is the way for a human. 10ms doesn't mean anything.
Please give us exact specifications of what you are trying to do (timings, are those two outputs happening at the same time, portd changing the sequence every time portb counts to eight,...). It will be way easier to give you examples of different possibilities of how to do it. |
Khansokhua
Posted: Tue Nov 09, 2021 5:37 pm |
| Code: | const int segment[7]={0x4F,0x66,0x6D,0x7C,0x07,0x7F,0x6F};
int led=1;
int i;
output_b(0x00);
output_a(0x02);
for(i=0;i<=7;i++)
circle:
delay_ms(250); //00000001-00000010-00000100-00001000-00010000-00100000=0x20
output_b(led); // B0- B1- B2- B3- B4- B5-
if(led==0x20) // B5
output_d(0x4F);// 3
delay_ms(250);
for(i=1;i<=7;i++)
{ // 1.index 2.index
output_d(segment[i]); // 4 5
led=led<<1;
output_b(led); // 01000000 10000000
delay_ms(250); // B6 B7
if(led==0x80)
led=1;
output_d(0x7C); // 6
delay_ms(250);
led=led<<1;
output_d(0x07); // 7
output_b(led); // B1
delay_ms(250);
led=led<<1;
output_d(0x7F); // 8
output_b(led); // B2
delay_ms(250);
led=led<<1;
output_d(0x6F); // 9
output_b(led); // B3
led=led<<1;
goto circle;
led=led<<1;
This is what wanted us to do by our teacher.We have only 40 minutes at laboratory. I have been struggling for couple hours just finished. So it was just
a question.There are being always three else question. I couldn't do it in given time. If there is a better way to done this, I would like to learn. I will be happy if anyone gives suggestion about anything in this circumstance. I give my time and want to do it right. Thanks all, respects. |
Posted: Wed Nov 10, 2021 6:23 am |
PrinceNai, if you look at the original code, he talks about displays, and
the whole thing uses 250mSec delays. So we 'know' that in fact this is
a human watched 'thing', so a few uSec (or even mSec), means nothing.
So 'human simultaneous', is what is needed, not 'real simultaneous'.  |
