Problem with Digital Pot MCP4017 driving
Goto page 1, 2, 3  Next
PICmodule
PostPosted: Tue Oct 26, 2021 12:59 am     Reply with quote
I'm trying to handle the Digital Potentiometer however have some problems. I do not know if it is the I2C itself or something else.
Compiler Version: 5.105
Controller: PIC24FJ128GA705
I tried HW I2C, but no results.
I tried the SF I2C, but no results.
I testing if pins are alive and connected to the proper pins of the MCP4017 just by sending sqr wave to each one, and looks like correct. I have connected 4K7k Resistors to 3V3 on both.
Now trying to multiple sending of the I2C requests to see CLK by DSO
//PICO_SDA         PIN_B2
//PICO_SCL         PIN_B3
#use i2c(MASTER, SCL=PIN_B3, SDA=PIN_B2, SLOW, RESTART_WDT, stream=A_I2C)
//#use i2c(MASTER, I2C2, SLOW, SMBUS, stream=A_I2C)
      printf("\n\rData Testing Start");
      int8 write_data[] = {0x0}; //select register 28
      int8 read_data[1];
         i2c_transfer(A_I2C, 0b01011110, write_data, 0b01011111, read_data, 1);
         printf("\n\rPOT DATA READ:%x\n\r", read_data[1]);
But system hang up. Any idea from your brains?
Thank you in Advance
MikeW
PostPosted: Tue Oct 26, 2021 1:12 am     Reply with quote
4K7 is a bit high. Thats fine for 5V, but I would use 3K3 for 3 volts
PICmodule
PostPosted: Tue Oct 26, 2021 1:14 am     Reply with quote
Yes, but this can not be the reason. I change them to smaller one. But I can not see any clocking
Thank you and Kind Regards
PostPosted: Tue Oct 26, 2021 1:38 am     Reply with quote
Here are your function parameters lined up with the CCS manual
parameters.
i2c_transfer([stream], address, wData,      wCount,     [rData], [rCount]);
You are putting the slave's read address (0x5F) in the wCount
parameter. That's not right.
PostPosted: Tue Oct 26, 2021 5:05 am     Reply with quote
With every I2C device, I use PCM P's 'I2C scanner' program that's in the code library before trying my code.
It'll find and report any I2C device and it's address.
Very handy, QUICK way to confirm you've got HW right, especially the device address !
PICmodule
PostPosted: Tue Oct 26, 2021 5:15 am     Reply with quote
Yes, I know, but trying it find it, and there ware so many solutions. Can you please share with me the link to the proper post with it. Thank you in advance
Kind Regards
PICmodule
PostPosted: Tue Oct 26, 2021 6:15 am     Reply with quote
Thank you, I found the proper one, and testing with software I2C, but results bad, seems much more IC found than exists. Found 112 devices :-)
It is reporting ACK every second address.
Going to check with DSO, however I tested separately each PIN and works fine
was generating sqr wave on each one.
PostPosted: Tue Oct 26, 2021 9:56 am     Reply with quote
hmm, never ever had that happen....
Are you SURE that clock and data of the PIC are connected to the clock and data of the MCP2017, and not data and clock ? It seems really odd.
Also, whenever testing, be sure to DISABLE the WDT ! There's zero need for it until the product is ready to be shipped out to the client.
PICmodule
update
I de-soldered the digital pot, pins are high (due to resistors).
If send sqr wave from controller are running well, therefore pins are connected to the IC and not shorted.
But still receiving the same, every second address is recognized as IC I2C.
I can not see any clk by DSO or data.
BR
PICmodule
PostPosted: Tue Oct 26, 2021 10:00 am     Reply with quote
I even switched to software I2C so have the ability to reverse pins, no way.
See below my I2C setup:
//PICO_SDA PIN_B2
//PICO_SCL PIN_B3
BR
PostPosted: Tue Oct 26, 2021 10:17 am     Reply with quote
The code only tests alternate addresses, since each device should/will
be on two addresses (for the read and write interface). It also doesn't
test the reserved addresses (<16).
The ACK, is the bus being held low. You would get an ACK on every
device, it the bus is not being pulled up properly or something is preventing
the bus going up properly.
Now you are using pins with Schmitt trigger inputs, so they will need to
go up to 2.64v before the line will be seen as high.
With the stream name specified in your setup, this should also be used
in the scanner program writes.
PICmodule
PostPosted: Tue Oct 26, 2021 11:26 am     Reply with quote
Ttelmah thank you for your post.
I again checked the pins, controller and PCB connection, by sending sqr wave to the pins related to the digital pot. I de-soldered it and there are nothing else on the connectivity between controller and digital pot pins (of course pull up resistors are).
I generated sqr wave and these are visible on both pins.
If using I2C SW or HW no clocking on this pins at all.
It seems to me as software problem, probably compiler.
         output_toggle(PIN_B3);
         output_toggle(PIN_B2);
         delay_ms(10);
more news when fixed it
BR
gaugeguy
PostPosted: Tue Oct 26, 2021 11:50 am     Reply with quote
Instead of output_toggle why not use something that simulates the way I2C works. I would also have them opposite polarity to check against shorts between the two.
output_low(PIN_B3);
output_float(PIN_B2);
delay_ms(10);
output_float(PIN_B3);
output_low(PIN_B2);
delay_ms(10);
PICmodule
PostPosted: Tue Oct 26, 2021 1:43 pm     Reply with quote
output_low(PIN_B3);
delay_ms(10);
output_low(PIN_B2);
delay_ms(10);
Hi, working properly also with your code. Hardware is fine. Must be software matter, and rather compiler
BR
PICmodule
PostPosted: Tue Oct 26, 2021 2:54 pm     Reply with quote
There is possible bug in I2C the version of Compiler 5.105 in PIC24FJ128GA705
If set hardware I2C like this
#use i2c(MASTER, I2C2, SLOW, SMBUS, stream=PICO_I2C)
the below handler is not working at all. No Clock, no data
int8 get_ack_status(int8 address)
int8 status;
    i2c_start(PICO_I2C);
    status = i2c_write(PICO_I2C, address);  // Status = 0 if got an ACK
    i2c_stop(PICO_I2C);
    if(status == 0)
       return(TRUE);
       return(FALSE);
If set I2C as a software like this
#use i2c(MASTER, SCL=PIN_B3, SDA=PIN_B2, FORCE_SW, SLOW, SMBUS, stream=PICO_I2C)
the below handler is partially working clock and data but only partially
int8 status;
on the below is hang-up here
sent already question to CCS
BR
Page 1 of 3
