Bill Turnip Guest
| Can you suggest the WARP-13 programmer? |
Posted: Sat Jun 28, 2003 2:26 pm |
Hello all -
I have exclusively been using the 16F877 (and 16F873) PICs with MPLAB and the PCM compiler, and I program these PICs using the ICD. By disconnecting the 4 or 5 connections to the ICD hardware and adding a pullup, I then use these parts in stand-alone applications. I would now like to work with other PICs, and will need a programmer. Is the WARP-13 a good one to use? The price seems reasonable, it can handle the parts I am planning to use, and it can be integrated into MPLAB. Am I missing anything?
Thanks in advance for your advice and suggestions.
Bill
Original Post ID: 144515621 |
Kenny
| Re: Can you suggest the WARP-13 programmer? |
Posted: Sat Jun 28, 2003 4:32 pm |
<font face="Courier New" size=-1>:=Hello all -
:= I have exclusively been using the 16F877 (and 16F873) PICs with MPLAB and the PCM compiler, and I program these PICs using the ICD. By disconnecting the 4 or 5 connections to the ICD hardware and adding a pullup, I then use these parts in stand-alone applications. I would now like to work with other PICs, and will need a programmer. Is the WARP-13 a good one to use? The price seems reasonable, it can handle the parts I am planning to use, and it can be integrated into MPLAB. Am I missing anything?
:= Thanks in advance for your advice and suggestions.
:=Bill
Yes, the Warp13a is excellent. Jim Robertson allows you to do your own firmware upgrades too so it's easy to keep up to date.
I use the in-circuit programming feature for code development together with PCW. This feature seems to be provided for final programming of the PIC on the target board rather than for code development.
I use two diodes, one in series with the programming voltage (needed because this line would leave the PIC reset after programming otherwise) and the other in series with a 10k pullup on the programming pin to prevent the programming voltage appearing on the +5V rail when power is inadvertently left off, the two diode cathodes joined at the pin.
Seems to work better with 10k pulldowns on RB6 (clock) and RB7 data).
Also I power the target circuit independently rather than take +5V from the Warp.
Perhaps I'm missing something - is it better to use ICD or bootloader together with MPLAB istead for code development?
Regards
Kenny
</font>
Original Post ID: 144515622 |
john cutler
Joined: 06 Sep 2003 Posts: 82 Location: Hot Tub, California
Posted: Sat Jun 28, 2003 6:12 pm |
YES!! It works great for me, and Jim is an outstanding guy. He has helped me in the past wikth early adoption on new PIC chips, before he was doing a new firmware release. Also, Peter Anderson in Maryland is his main US rep, and he carries parts for upgrades. I don't know of a better programmer - especially for the $$.
JC
Original Post ID: 144515623 |
Dave Yeatman Guest
Posted: Sat Jun 28, 2003 8:05 pm |
Yes!! I upgraded mine a while back to add the 18 series capability and the new high speed mod and it works great for both...zero problems.
Dave
:=Hello all -
:=Bill
Original Post ID: 144515624 |
Pete Smith Guest
Posted: Sun Jun 29, 2003 3:41 am |
:=Hello all -
Not missing anything at all!
FWIW, if you don't use MPLAB to actually develop the code, you now don't need MPLAB at all.
My situation is that I use Ultraedit to compiler - much nicer than MPLAB. I've linked Ultraedit into the programmer controller, so I compile with a keystroke and program with one too.
It's even got those 5 wires you need (Vdd, Vss, MCLR, B6 and B7) on the board on a molex connector, which really helped me (until someone told me that Surface Mount was the work of the Devil, totally unsuitable for development work - despite the fact that hadn't stopped me for 3 years before - and we've now got to do everything through hole with no ICSP facility), because I could just plug in the lead at both ends, and go.
Definitely worth it IMO.
I was "forced" into using it when we couldn't get 16LF876's, but only the 876A part, which at the time, Picstart Plus didn't support.
Pete.
Original Post ID: 144515630 |
Bill Turnip Guest
| Re: Can you suggest the WARP-13 programmer? Gracias! |
Posted: Sun Jun 29, 2003 3:26 pm |
Thanks for the input everyone!!!
Bill
Original Post ID: 144515637 |
