Error with function pointer
afk_pic
PostPosted: Wed Sep 08, 2021 9:15 am     Reply with quote
I have this error and I need help, because this code works in other projects.
I have this error:
*** Error 144 "source\main.c" Line 297(1,1): No valid assignment made to function pointer  1779  from=??0 0 SCR=9430
My code gets a character from UART on every interrupt and it stores all chars received until the char "\0" carriage return. Then I pass this string by parameter to a function to analyze this string and parse arguments.
My main have this code:
main.c
#include "halRS232.h"
#if EXEC_UART_INT
#INT_RDA                     //interrupciones del puerto rs232 rx
void  rda_isr(void)
   char rx = getc(UART1);
   char endMsg = rxStringFromRS232(rx, rxRs232, 20);
   if (endMsg == 1)
      msgDecoder(rxRs232, cmd, arg1, arg2, arg3);    //the error is here
      flagRS2323RxMsg = TRUE;
   clear_interrupt(INT_RDA);
   enable_interrupts(INT_RDA);
#else
halRS232.c
void msgDecoder (char* msgToAnlze, char* cmd, char* arg1, char* arg2, char* arg3)
   static char* stringResult;
   char delimiter[] = " ";
   char numArgs = 0;
   strcpy(cmd, "");
   strcpy(arg1, "");
   strcpy(arg2, "");
   strcpy(arg3, "");
   stringResult = strtok(msgToAnlze, delimiter);
   strcpy(cmd, stringResult);
   if(stringResult != NULL){
      while(stringResult != NULL){
         numArgs = numArgs + 1;
            switch (numArgs) {
              case 1:
              case 2:
                 strcpy(arg1, stringResult);
              case 3:
                 strcpy(arg2, stringResult);
              case 4:
                 strcpy(arg3, stringResult);
              default:
            stringResult = 0;
         stringResult = strtok(NULL, delimiter);
   //fin
halRS232.h
void msgDecoder (char* msgToAnlze, char* cmd, char* arg1, char* arg2, char* arg3);
Any idea??
Regards and thanks.
PostPosted: Wed Sep 08, 2021 9:46 am     Reply with quote
I don't see a declaration of a function pointer anywhere in your program.
You also didn't post your variable declarations.
This guy is actually using function pointers and he gets the same
error message as you do:
http://www.ccsinfo.com/forum/viewtopic.php?t=59013&start=4
afk_pic
PostPosted: Wed Sep 08, 2021 11:50 pm     Reply with quote
this are my variables:
unsigned char rxRs232[20];
unsigned char dummyString[20];
unsigned char command[10], argv1[10], argv2[10], argv3[10];
bool flagRS2323RxMsg = FALSE;
I insist in the fact that this code works in other project, has the same variable declarations even halRS232.c /.h are identical...very strange.
Thanks!
EDIT:
I have solved the issue: only I moved the function declaration msgDecoder to a new file .h and .c
EDIT2:
Calling the function in my void main (void) it's works. But if I call the function in the interrupt routines gives me the same error, check the op thread.
#if EXEC_UART_INT
void  rda_isr(void)
   if (endMsg == 1)
      msgDecoder(rxRs232, command, argv1, argv2, argv3);
#else
EDIT3:
Looks the problem is with the name of the header/source file...I copied the function to another header/source file and it works.
