ASM delay control [Solved]
vtrx
PostPosted: Sun Sep 05, 2021 6:48 am     Reply with quote
I have a routine that uses a delay that needs to be written in ASM.
Using delay_ms(x) cannot be used because the routine gets out of sync.
The ideal delay routine for my routine is:
char DELAY0,DELAY1,DELAY2;
        #asm#
          delay:
            movlw   6
            movwf   DELAY0
            movlw   100
            movwf   DELAY1
            movwf   DELAY2
          delay_loop:
            decfsz  DELAY2
            goto    delay_loop
            movwf   DELAY2
            decfsz  DELAY1
            goto    delay_loop
            movwf   DELAY1
            decfsz  DELAY0
            goto    delay_loop
          #endasm
The problem is that I can't change the delay using a variable.
char DELAY0,DELAY1,DELAY2,VAR;
VAR= 100;
          #asm#
          delay:
            movlw   6
            movwf   DELAY0
            movlw   var//100
            movwf   DELAY1
            movwf   DELAY2
          delay_loop:
            decfsz  DELAY2
            goto    delay_loop
            movwf   DELAY2
            decfsz  DELAY1
            goto    delay_loop
            movwf   DELAY1
            decfsz  DELAY0
            goto    delay_loop
          #endasm
This way it has no effect.
What would be the correct procedure?
PostPosted: Sun Sep 05, 2021 7:02 am     Reply with quote
you need to post your real code as whether you use 'delay_ms() 'or your ASM version, won't change your 'out of sync' problem. delay_ms() gets converted into ASM so same thing....
BTW, simply dump the listing and you'll see the delay_ms() code.
Remember that delays STOP the PIC from doing ANYTHING unti the delay is finished.
What is 'out of sync' ?
What are you trying to do ?
We need more info (code....) to see what's happening.
PrinceNai
PostPosted: Sun Sep 05, 2021 7:30 am     Reply with quote
Are you using interrupts? Those will change the delay. Have a look at this for delays:
http://www.piclist.com/techref/piclist/codegen/delay.htm
vtrx
PostPosted: Sun Sep 05, 2021 1:45 pm     Reply with quote
The code is an adaptation of an AVR/GCC code.
It's a little long to explain, but even the original code for AVR, the original delay is in ASM.
     if(currentstart > (messagelength - MODULESNUMBER-1)){currentstart = 0;};
      while(currentstart < (messagelength - MODULESNUMBER) && scroll_on ==1)
         currentcolumn = 0;
        while (currentcolumn < 8)
          #asm#
          delay:
            movlw   6
            movwf   DELAY0
            movlw   150
            movwf   DELAY1
            movwf   DELAY2
          delay_loop:
            decfsz  DELAY2
            goto    delay_loop
            movwf   DELAY2
            decfsz  DELAY1
            goto    delay_loop
            movwf   DELAY1
            decfsz  DELAY0
            goto    delay_loop
          #endasm
            if(usb_kbhit(1))
                usb_get_packet(1, in_data,USB_EP1_RX_SIZE);
               if(in_data[0] =='7')
                   atraso = in_data[1];
               if(in_data[0] =='8')
                   scroll_on = 0;
               if(in_data[0] =='9')
                   scroll_on = 1;
            for (letter=0; letter< MODULESNUMBER; letter++)
               for(i=0; i<8; i++)
                  inputbuf[i] = fontdef[(int16)(messagebuf[currentstart + letter])*8 + i];  //font_2[(int16)(messagebuf[currentstart + letter])*8 + 8-x];
               }  // end of 'i' loop
               for(i=8; i<16; i++)
                  inputbuf[i] = fontdef[(int16)(messagebuf[currentstart + letter + 1])*8 + (i-8)];//font_2[(int16)(messagebuf[currentstart + letter + 1])*8 + 8-x];
               for(unsigned int8 i = 0; i < 8; i++)
                  for(signed int8 j = 7; j > -1; j--)
                     outputbuf[i+(letter << 3)] = (outputbuf[i+(letter << 3)] << 1) | ((inputbuf[j + currentcolumn] >> (7 - i)) & 0x01);
                  }  // end of 'j' loop
               } // end of 'i'loop
            } // end of 'letter' loop
            for(i=0; i<8; i++)
               for (j=0; j < MODULESNUMBER ; j++)
                  commands[(j*2)] = i+1;
                  commands[(j*2)+1] = outputbuf[i + ((MODULESNUMBER - j -1 ) << 3)];   //
               MAX7219_sendN(MODULESNUMBER, commands);
            currentcolumn++; // increase current column for scrolling
         } // end of 'currentcolumn' WHILE LOOP for scrolling single character
         currentstart++;  // increase current position on text to scroll
     }// end of LOOP for 'currentstart'  for scrolling all the text
I need to control the delay duration, programmed in ASM, externally.
Delay_ms(xx) probably uses 'call' and that could be the problem.
PostPosted: Sun Sep 05, 2021 3:55 pm     Reply with quote
What does "out of sync" mean ? Gets out of sync with what ?
vtrx
PostPosted: Sun Sep 05, 2021 4:17 pm     Reply with quote
The above routine shifts characters in an array of LEDs, using delay_ms(xx), the characters jump out of order, using CCS/PIC or AVR/GCC.
PostPosted: Sun Sep 05, 2021 4:45 pm     Reply with quote
Do you have an interrupt routine, and are you using delay_ms()
inside the routine ?
What compiler warning messages do you get ?
vtrx
PostPosted: Sun Sep 05, 2021 5:13 pm     Reply with quote
No.
I found my mistake.
In the instruction 'movlw 150',the correct one is 'movf DLY,w'.
I don't know why in the two compilers just in ASM it works fine.
char DYL;
DLY = 150;
          #asm#
          delay:
            movlw   120
            movwf   DELAY0
            movf    DLY,w
            movwf   DELAY1
            movwf   DELAY2
          delay_loop:
            decfsz  DELAY2
            goto    delay_loop
            movwf   DELAY2
            decfsz  DELAY1
            goto    delay_loop
            movwf   DELAY1
            decfsz  DELAY0
            goto    delay_loop
          #endasm
