I am trying to get result from adc pin 12F675
swapnil
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
PostPosted: Sat Aug 21, 2021 3:24 am     Reply with quote
    #include <12f675.h>
    #device adc=10
    #fuses INTRC_IO, NOWDT, PUT, BROWNOUT, MCLR
    #define RELAY   PIN_A3       // Relay for 110 v switch
    #define LED     PIN_A5       // TRANSISTOR for chg cut for nicd battery
      int16 adc_value;
      float batt_volt;
      float mns_volt;
      set_tris_a(0b0000111);
      setup_adc(ADC_CLOCK_DIV_32);
      setup_adc_ports(sAN0|sAN1|sAN2);
            set_adc_channel(0);// Battery Voltage Sense
             set_adc_channel(2);// mains  Voltage Sense
            adc_value=read_adc();
            batt_volt=adc_value/20.449;
             mns_volt=adc_value/20.449;
            //batt_volt=adc_value*(5/1023);//20.449;
            if (batt_volt >= 13.8 )//<=14.0)// && batt_volt <= 1.0 )
                  delay_ms(3000);
                  output_high(LED);
                if (mns_volt <= 1.0 )//<=3.0)
                delay_ms(3000);
                 output_high(RELAY);
               output_low(RELAY);
                  delay_ms(3000);
                  output_low(LED);
heroswap1981
PostPosted: Sat Aug 21, 2021 3:31 am     Reply with quote
You have to work like this:
   delay_us(10); //The channel has to be selected long enough
   //for the signal to acquire -> Tacq. Check the data sheet for what this
   //needs to be (9.55uSec min on your chip).
   adc_value=read_adc(); //This now reads the battery voltage
   delay_us(10);
   adc_value=read_adc(); //This now reads the main voltage sense.
Sequence is always select channel, wait for signal to acquire, then sample
this.
