Does CCS provide the source for the ccsbootloader application that comes with the compiler installation?
I need to be able to load the pic from a wifi module with an arm processor. Has anyone here done that? I could reverse engineer it from the bootloading code, but I don't see a point in re-writing something that should be directly available from CCS.
Posted: Thu Jun 03, 2021 12:15 pm
There is nothing at all 'to' the bootloader code.
It just sends the .hex file over the serial port. Key though is the sending
device _must_ implement XON/XOFF handshaking, and stop when XOFF
is received.
I've sent files from a Unix command line by simply setting up the serial and
piping the files to the serial port.
