Error 112: Function used but not defined
gerard.perez
PostPosted: Thu Mar 25, 2021 12:17 pm     Reply with quote
Good afternoon,
I get the error mentioned in the subject when I compile my main program.
In my .c file where I have the main I make an include of a .h with the function header and, in principle from the project options I add the .c corresponding to the .h include.
When using a function of the .c I get this error when I try to compile.
If someone can help me I would be very grateful.
Thank you very much in advance.
Buenas tardes,
me aparece el error comentado en el asunto cuando compilo mi programa principal.
En mi archivo .c donde tengo el main hago un include de un .h con la cabecera de la función y, en principio a partir de las opciones del proyecto añado el .c correspondiente al include del .h.
Al usar una función del .c me salta este error cuando intento compilar.
Si alguien puede ayudarme se lo agradecería bastante.
Muchas gracias de antemano.
PostPosted: Thu Mar 25, 2021 10:24 pm     Reply with quote
Which one of these IDE's are you using ?
- CCS IDE
- MPLAB X
- MPLAB vs. 8.92
I don't know what this means. What do you mean by "in principle" ?
Tell us the name of the function that is not defined.
