10 bits conversion
raman00084@gmail.com
10 bits conversion
PostPosted: Wed Jan 06, 2021 3:44 am     Reply with quote
i have a 10 bits in an array
bits[]={1,1,1,1,1,1,1,1,1,1};
the value of the above is = 1023
now how can i convert the bits in the array and store the result in int16 bit variable.
PostPosted: Wed Jan 06, 2021 6:55 am     Reply with quote
There are lots of different ways. However by far the most efficient
(depending on how the 'bits' are stored), is to use a union or a #locate.
Now I say 'depending on how the bits are stored'. This approach only works
if they are stored as int1 values.
union {
   unsigned int16 word;
   int1 bits[10];
} combiner;
//Then if combiner.bits is used as the array, combiner.word contains
//the 16bit value.
//You can also do the same effective thing using #locate.
int1 bits[] = {1,1,1,1,1,1,1,1,1,1};
#locate word=bits;
//Then word is the int equivalent of the int1 array.
If the values are not int1, then you have to build the result manually.
Unfortunately, this then wastes a lot of processor time. The most efficient
way is:
unsigned int16 from_bits(void)
   unsigned int16 mask=1, result=0;
   unsigned int8 ctr;
   for (ctr=0;ctr<10;ctr++)
      if (bits[ctr])
         result+=mask;
      mask<<=1;
   return result;
PostPosted: Wed Jan 06, 2021 7:33 am     Reply with quote
union {
   int1 bits[10];
} combiner;
//the 16bit value.
thank you for your reply  your code is working.
this is my code this is also working but yours is simple!
while(true)
unsigned int8 dd[]={0,0,0,0,0,0,0,0,0,1};
unsigned int16 val=0;
unsigned int16 mul=0;
for(int8 i=0;i<10;i++)
       mul=mul*2;
       if(mul==0)
        mul=1;
   if(dd[i]==1)
    val=val+mul;
 lcd_gotoxy(1, 1);
 printf(lcd_putc1, "%04lu",val);
#locate word=bits;
way is:
   unsigned int8 ctr;
      if (bits[ctr])
         result+=mask;
      mask<<=1;
   return result;
PostPosted: Wed Jan 06, 2021 7:58 am     Reply with quote
yeesh, I was looking and thinking about this while coffee slowly dripped,dripped, drip...
Mr. T's union is perfect !!
I was looking at a loop with bit_test to make the sum then sorry, got distracted with fresh coffee...
Providing the 'order' of the bits is correct, the union is the fastest,easiest way to do it.
