Hex2Bin for bootloader
Goto page Previous  1, 2
georpo
PostPosted: Sat Dec 19, 2020 11:31 am     Reply with quote
Yes of course.
What I mean by brick the PIC Laughing is brick the main application firmware.
Not the bootloader. Sure when the bootloader sees a bad line it can do something. But the main firmware is already corrupt. Maybe if I could have a backup image of the working firmware in the external flash which would need a bigger flash Rolling Eyes
The idea of having a PIC big enough to have a backup partition is also very good but I am at 98% of a PIC24FJ128GA204.
So, what do you guys do to play safe?
George.
georpo
PostPosted: Sat Dec 19, 2020 12:10 pm     Reply with quote
OK, different approach.
21% of the PIC24FJ128GA204 is firmware and the rest is fonts in "const char" tables.
Can I write the font tables to the pic using programmer and then update only the firmware through the bootloader? This solves everything. The "firmware only" hex can fit in my ext flash.
How can I put the tables in specific region of the PIC memory?
How will I declare the tables in the code for reading?
Thanks!
George.
PostPosted: Sat Dec 19, 2020 2:25 pm     Reply with quote
While I don't use that PIC, I'm sure the answers are yes....
Others can guide you as to how it's done but offhand, I'd say that when you program the PIC for the bootloader , you can 'burn' the 'font tables' at the same time( say in high memory ),then protect it ,same as the bootloader.
georpo
PostPosted: Sat Dec 19, 2020 4:08 pm     Reply with quote
Yes I am also certain that it can be done.
I guess with some #org statements before the tables.
But where should I locate the tables...???
And are there page boundaries etc?
It is a good idea to program the bootloader and the fonts with the programmer and then have the bootloader download the firmware but I am missing basic knowledge on this... Embarassed
In the "view->program memory" I could not find anything looking like a lookup table.
George.
PostPosted: Sun Dec 20, 2020 1:55 am     Reply with quote
You would have to use a #ORG statement to locate your const values
to a fixed set of locations. Otherwise there is a risk they will move. You would
need to have your code having the #ORG, then loading all these tables only
and then switching the #org back to it's default. Otherwise you risk the
constant tables used to do things like initialise variables making the main
font tables move. Then use a tool like HEXit, to import your hex
file, and only export the parts you want to program.
georpo
PostPosted: Sun Dec 20, 2020 3:55 am     Reply with quote
So, I need a program with the bootloader and far back at the memory my font tables.
The question is how far is far enough?
How long is each table so I can start the next table after the previous?
And then in the actual code how do I access the fonts since they are not in the code?
#org Font1Location
const char Font1[]={0,0,0,0,0,0,0,0,0,0,0,0};
#org Font1Location + Font1TableSize +1
const char Font2[]={0,0,0,0,0,0,0,0,0,0,0,0};
How can I do the above?
Thank you for the support.
George.
PostPosted: Sun Dec 20, 2020 6:46 am     Reply with quote
OK, remember I don't use that PIC or bootloaders but...generally speaking...
PICs have 'banks' of memory. The size of the bank depends on the PIC family.
Let's say your PIC has 128KB of memory consisting of 4 banks, each 32KB in size. Call them Bank 0,1,2,3.
The bootloader program will always go into bank 0 (lowest address),well probably...
Your 'font tables' should go into bank 3, the 'top' of memory. Now if the table is larger than 32KB, it'd have to go into bank2 AND bank3.
So if table fit into bank 3, then your main() program can be in banks 1 and 2. If the table is in banks 2 and 3, obviously main() can only fill bank1.
You'll have to figure out how large your font table is. One way is to create a small program with it in, then look at the 'disassembled listing', find the table, subtract end address from start address.
As for accessing the tables, the compiler will know their start location...
Keep in mind that when you program the PIC for bootloader and tables, you need to 'protect' them so that when you download 'main()' it doesn't overwrite the bootloader or the font tables.
Hopefully someone using the 24 series PICs can offer help
PostPosted: Sun Dec 20, 2020 7:14 am     Reply with quote
The answer is in the line 'the compiler knows'.
Load the symbol file.
For your const variables, it'll show where they are placed in the ROM.
Don't do multiple #ORG's. Just have a single #ORG, and load all the font
tables, then switch the ORG back to default operation.
georpo
PostPosted: Sun Dec 20, 2020 7:21 am     Reply with quote
I thought that the #org is only for the code or table following the #org. also I cannot understand what you mean by
and how will I use the font tables in the actual code since they are not there?
also I think that if I try to compile the bootloader with the fonts included I will get the out of Rom error because I use #define loader pages 3
George.
PostPosted: Sun Dec 20, 2020 8:48 am     Reply with quote
//Make 'Font1Location large enough to hold all the fonts'
#org Font1Location default
//now define your consts...
//as many as wanted
#org default
The 'default' keyword, makes the #ORG switch 'everything to it's defined
range. Then using this without a range, switches it back.
The reason this is important, is that const declarations, may come with extra
'overhead'. The little program to actually access it is sometimes included.
Result is that it takes more ROM space than it's 'size'....
So trying to do the #ORG's with fixed ranges as you show is likely not to
work.
georpo
PostPosted: Sun Dec 20, 2020 12:02 pm     Reply with quote
I do not get it but I will study and try.
OK, I will find the total size of all the fonts and calculate the address.
#org 0xABCD default
unsigned char Font1[]={0,0,0,0,0,0,0,0,0,0};
unsigned char Font2[]={0,0,0,0,0,0,0,0,0,0};
unsigned char Font3[]={0,0,0,0,0,0,0,0,0,0};
#org default
I do not understand the "without a range" that you say.
Your example does not have a range. It has the location only.
But again, in the firmware code, the font tables are not included.
So how do I use them? I will get errors undefined identifier etc.
Yes, the tables will be at the end of memory but my firmware dos not know this.
George.
PostPosted: Sun Dec 20, 2020 12:12 pm     Reply with quote
The point is you include them in the application code when you generate
this, Then include then in the same way in the original bootloder code.
The application includes them, but you then omit them from what you
actually send to the bootloaxder. Since they are in the same format,
and the same size the code then merrily talks to the already loaded
version.
georpo
PostPosted: Sun Dec 20, 2020 12:16 pm     Reply with quote
OK, now we got something Very Happy
But I have to define a bit value in LOADER_PAGES so as to fit the fonts. Right?
In that case, the bootloader code will be very big with a huge gap in the middle.
Am I wrong?
George.
PostPosted: Sun Dec 20, 2020 1:13 pm     Reply with quote
No, you don't include these into the area protected and used by the
bootloader. Yes, you load them, but they are not part of the actual
bootloader.
Page 2 of 2
