From 5066 to 5094.
hmmpic
From 5066 to 5094.
PostPosted: Tue Jul 07, 2020 11:05 pm     Reply with quote
Chip is a 12F1840
Long time on my 5.066, yesterday i made a update to 5.094 and i don't understand this.
What is going on here?
5094
....................   control.Delay=2900+(state*130L); //2900,130,15 2900,100,20 2500,90,20 3000,80,25
0114:  CLRF   @7A
0115:  MOVF   state,W
0116:  MOVWF  @@38
0117:  MOVF   @7A,W
0118:  MOVWF  @@39
0119:  MOVF   @@39,W
011A:  MOVWF  ??65535+1
011B:  MOVF   @@38,W
011C:  MOVWF  ??65535
011D:  CLRF   @MULS1616.P1+1
011E:  MOVLW  82
011F:  MOVWF  @MULS1616.P1
014D:  MOVF   @79,W
014E:  MOVWF  @7A
014F:  MOVF   @78,W
0150:  ADDLW  54
0151:  MOVWF  @78
0152:  MOVLW  0B
0153:  ADDWFC @7A,F
0154:  MOVF   @78,W
0155:  MOVWF  Control+2
0156:  MOVF   @7A,W
0157:  MOVWF  Control+3
5066
0115:  CLRF   ??65535+1
0116:  MOVF   state,W
0117:  MOVWF  ??65535
0118:  CLRF   @MUL1616.P1+1
0119:  MOVLW  82
011A:  MOVWF  @MUL1616.P1
012F:  MOVF   @78,W
0130:  ADDLW  54
0131:  MOVWF  Control+2
0132:  MOVLW  0B
0133:  ADDWFC @79,W
0134:  MOVWF  Control+3
Complicated to read, i must find out in the .sym file what the location was. List file in configuration is set to Symbolic.
The following is the init code for all static assignment. Why have CCS changed the logic name to addresses?
5066
MOVLW  FF
0194:  MOVLB  00
0195:  MOVWF  stateold
0196:  CLRF   count
0197:  MOVLW  04
0198:  MOVWF  ms50
5094
MOVLW  FF
01BC:  MOVLB  00
01BD:  MOVWF  32
01BE:  CLRF   33
01BF:  MOVLW  04
01C0:  MOVWF  34
PostPosted: Wed Jul 08, 2020 12:03 am     Reply with quote
The 'default' for all the compilers, is to use addresses, not symbolic names.
On your previous compiler, you must have changed the setting to use
symbolic. This setting has not been upgraded, so you need to make it
again.
Options
Project
Output Files
List file. Symbolic.
The default is 'CCS Basic'.
hmmpic
PostPosted: Wed Jul 08, 2020 1:22 am     Reply with quote
No it is set, all other in the .lst it is right but not in the section for static assign.
Just after the main() in the .lst file.
PostPosted: Wed Jul 08, 2020 2:32 am     Reply with quote
OK. There is no sign at all that this is a 'static assignment'. C as such does
not have a distinct 'static assignment'. All that happens is that static
variables if they have values assigned at declaration, have these initilalised
before the start of the main code, instead of in the sub-routines where they
are declared.
Now what you show looks like a post-declaration assignment to a possibly
'static' variable, but cannot be a 'static assignment' in the normal meaning
of this phrase (since in C assignments to static's done at declaration, can
only use constants). This looks like a post declaration initialisation.
A 'static assignment' in C , would be a declaration like:
static struct {
   int32 val;
   int16 another;
} a_structure = {0x11223344,0x1122};
Now, why the compiler has changed what you are seeing, would need
study with some complete code, to actually see what it is doing. It looks
as if it is using one extra scratch level in passing data to the mul function.
Scratch variables never use symbolic notation.
Tracking back compiler versions to see when this actually happened, and
then what 'remarks' were made about what this compiler version 'fixed',
might well give a clue.
hmmpic
PostPosted: Sun Jul 12, 2020 6:34 am     Reply with quote
I have set List file in configuration to use Symbolic, and it is some time but not always.
I try one more example:
#include <18f26k22.h>
#use delay(clock=8M,int)
void Test1(){
 int8 t1=0x10;
 static int8 t2=0x20;
 t1=0x11;
 t2=0x21;
void main(void){
 Test1();
Compile... Now look at the .lst file.
This look ok.
.................... void Test1(){
00004:  MOVLW  10
00006:  MOVWF  t1
....................  int8 t1=0x10;
....................  static int8 t2=0x20;
....................  t1=0x11;
00008:  MOVLW  11
0000A:  MOVWF  t1
....................  t2=0x21;
0000C:  MOVLW  21
0000E:  MOVWF  t2
00010:  GOTO   0036 (RETURN)
Here CCS initializing the static int8 t2, you see the static int8 t2 is used as it's ddress and not with the name as in 5066.
.................... void main(void){
00014:  CLRF   TBLPTRU
00016:  BCF    RCON.IPEN
00018:  MOVLW  60
0001A:  MOVWF  OSCCON
0001C:  BCF    OSCTUNE.PLLEN
0001E:  BCF    OSCTUNE.INTSRC
00020:  MOVLB  F
00022:  CLRF   x38
00024:  CLRF   x39
00026:  CLRF   x3A
00028:  CLRF   CM2CON1
0002A:  CLRF   CM2CON0
0002C:  CLRF   CM1CON0
0002E:  MOVLW  20
00030:  MOVWF  04 -> This is the static int8 t2 location fount in the .sym file
From the .sym file
004     Test1.t2 ->Location for my static int8 t2
005     Test1.t1
