Interrupt variable type
sebalitter
PostPosted: Wed May 20, 2020 7:52 am     Reply with quote
Hi
what kind of variable should i put to toggle between two INTERRUPT types like INT_IOC_A3_H2L and INT_IOC_A5_H2L.
let me explain what i have in mind.
 int32 interrupcion = INT_IOC_A3_H2L;
    if(toggle_sensors_vcc==1){
        interrupcion = (int32)INT_IOC_A5_H2L;
 set_timer1(0); // clear timer
 clear_interrupt(interrupcion);   // Error#51  A numeric expression must appear here  ::
 cant =0;
      while(!interrupt_active(interrupcion) && cant<4000 ){  //same error here
          cant++;
ticks = get_timer1();
thank you
PostPosted: Wed May 20, 2020 8:00 am     Reply with quote
quick answer...
According to the manual the clear_interrupt(...) function requires a CONSTANT not a variable.... so you MUST put the 'name' of the interrupt you're using.
The PIC header file will have a list of available interrupts and their names.
sebalitter
PostPosted: Wed May 20, 2020 8:19 am     Reply with quote
temtronic wrote:
quik answer...
Thanks for the answer!
in the header file it says...
_bif void clear_interrupt(int32 interrupt);
_bif int1 interrupt_active(int32 interrupt);
But thats fine, so my solution was this one..
      if(toggle_sensors_vcc)
            clear_interrupt(INT_IOC_A5_H2L);
        clear_interrupt(INT_IOC_A3_H2L);  //clear  interrupt flag
        cant =0;
      // wait for CCP1 interrupt.  CCP1 will interrupt when PIN_ULTRASONIC_ECHO
      // goes low due to CCP_CAPTURE_FE passed to setup_ccp1()
                while(!interrupt_active(INT_IOC_A5_H2L) && cant<4000 ){
                    cant++;
        }else{
                 while(!interrupt_active(INT_IOC_A3_H2L) && cant<4000 ){
                    cant++;
It should be another improved solution for this. please let me know.
PostPosted: Wed May 20, 2020 9:34 am     Reply with quote
Header files normally have this format ...
// Constants used in ENABLE/DISABLE_INTERRUPTS() are:
#define GLOBAL                    0xF2C0
#define PERIPH                    0xF240
#define INT_RTCC                  0x00F220
#define INT_TIMER0                0x00F220
#define INT_TIMER1                0x009D01
#define INT_TIMER2                0x009D02
#define INT_TIMER3                0x00A002
#define INT_EXT_L2H               0x5000F210
#define INT_EXT_H2L               0x6000F210
... this is part of the PIC18F46K22.h file
PostPosted: Wed May 20, 2020 10:35 am     Reply with quote
sebalitter wrote:
temtronic wrote:
quik answer...
Note that those lines in the header file have the _bif in front of them, that's an annotation meant to indicate that those are just declarations used to help IDE's identify which builtin functions are created by the compiler. Always check versus the compiler manual as some functions are compile time constant only (and the C language does not provide a way to express that, so the function declaration doesn't help there).
PostPosted: Wed May 20, 2020 5:39 pm     Reply with quote
there are NO _bifs in the PIC18F46K22.h file tha I use....
PostPosted: Wed May 20, 2020 7:20 pm     Reply with quote
You're using an old compiler version.
PostPosted: Wed May 20, 2020 7:38 pm     Reply with quote
They added it some time ago...I forget when, sometime after MPLABX v2 because it was highlighting all the CCS functions as undefined (with the syntax highlighter).
PostPosted: Thu May 21, 2020 4:23 am     Reply with quote
re:
yeah, it's old, I'm old, sigh.....
not getting any younger , the older I get
great...now I depressed too !
