use #pin_select problem (Solved Bummer)
Jerry I
PostPosted: Sat May 09, 2020 6:51 pm     Reply with quote
Using PIC18F27K40, CCS PCH C Compiler, Version 5.078
I am having problem assigning peripherals using pin select option.
Pin select options from header file below
////////////////////////////////////////////////////////////////// PIN_SELECT
// #pin_select function=pin
// Valid Pins:
//    PIN_A0,PIN_A1,PIN_A2,PIN_A3,PIN_A4,PIN_A5,PIN_A6,PIN_A7,PIN_B0,PIN_B1,
//    PIN_B2,PIN_B3,PIN_B4,PIN_B5,PIN_B6,PIN_B7,PIN_C0,PIN_C1,PIN_C2,PIN_C3,
//    PIN_C4,PIN_C5,PIN_C6,PIN_C7,PIN_E3
// Input Functions:
//    INT0,INT1,INT2,T0CK,T1CK,T1G,T3CK,T3G,T5CK,T5G,T2CK,T4CK,T6CK,ADACT,CCP1,
//    CCP2,CWGIN,MDCARL,MDCARH,MDSRC,U1RX,U1CK,SCK1IN,SCL1IN,SDI1,SDA1IN,SS1IN,
//    U2RX,U2CK,SCK2IN,SCL2IN,SDI2,SDA2IN,SS2IN,T0CKI,T1CKI,T3CKI,T5CKI,T2CKI,
//    T4CKI,T6CKI,CCP1IN,CCP2IN,RX1,CK1,U1CKIN,RX2,CK2,U2CKIN
// Output Functions:
//    NULL,CWG1OUTA,CWG1OUTB,CWG1OUTC,CWG1OUTD,CCP1OUT,CCP2OUT,PWM3OUT,PWM4OUT,
//    U1TX,U1DT,U2TX,U2DT,C1OUT,C2OUT,SCK1OUT,SCL1OUT,SDO1,SDA1OUT,SCK2OUT,
//    SCL2OUT,SDO2,SDA2OUT,T0OUT,CLKROUT,DSMOUT,ADGRDA,ADGRDB,PWM3,PWM4,TX1,DT1,
//    TX2,DT2,SCK1,SCL1,SDA1,SCK2,SCL2,SDA2,TMR0OUT
Trying to assign 2 external clock counter inputs to these pins.
#PIN_SELECT T3CK=PIN_B1
#PIN_SELECT T1CK=PIN_B2
error shown below on compile
*** Error 7 Line 108(12,24): Invalid Pre-Processor directive Invalid Pin: PIN_B2 can not be assigned to T1CK
Also tried #PIN_SELECT T1CK=PIN_B1 THIS DOES NOT WORK
#PIN_SELECT T3CK=PIN_B1 // is fine
#PIN_SELECT T3CK=PIN_B2 // Also Fine
It will let me assign to other pins on PORTA & PORTC
Can you only assign 1 peripheral to a PORT
#PIN_SELECT T1CK=PIN_A5   // Works
#PIN_SELECT T1CK=PIN_C1    // Works
It appears to be a valid input for pin select option?.
Is this a compiler problem ??
Thanks for all the help.
PostPosted: Sat May 09, 2020 7:18 pm     Reply with quote
Get the 18F27K40 datasheet:
http://ww1.microchip.com/downloads/en/DeviceDoc/PIC18LF27_47K40-Data-Sheet-40001844E.pdf
Look at this table on page 306:
Table 17-1. PPS Input Selection Register Details
Find Timer1 clock in the left column and look over on the right and see
that it only works with ports A and C.
Jerry I
PostPosted: Sat May 09, 2020 7:52 pm     Reply with quote
Thanks for the info.
I should pay more attention to the datasheet. Bummer.
Thanks again.
PostPosted: Sun May 10, 2020 2:04 am     Reply with quote
Yes, it's annoying isn't it....
It's a bit of the 'evolution' of PPS. The latest chips allow things to route
to any pin, while the older PPS chips have restrictions like this. Sad
PostPosted: Sun May 10, 2020 4:13 am     Reply with quote
At least you don't have to wait 15 minutes waiting for the UV eraser to make your PIC 'just like new' again, an again , and again........ Very Happy
bkamen
PostPosted: Tue May 12, 2020 10:48 pm     Reply with quote
I remember those days.
I have some of those PICs sitting up behind me.
LoL.... those were the days.
Dazed and confused? I don't think so. Just "plain lost" will do. :D
PostPosted: Wed May 13, 2020 12:13 am     Reply with quote
Yes, and it was the fact that it took so long, that even if you had perhaps
six chips in use, and four chips in the eraser, you still found you had run out
and had to wait...
The launch of electrically erasable chips was a 'magic' day. Smile
