18f46k22 UART problem
PrinceNai
PostPosted: Sun Feb 16, 2020 7:08 am     Reply with quote
Dear Sirs,
I'm making a test project with 18F46K22 (internal oscillator) and HC-12 serial to wireless modules. Everything is on one board, the first HC-12 is on UART1 and the second is on UART2. Both are initialized to 9600 baud, same channel, same function mode, same power. My uarts are defined like this:
#use rs232(baud=9600,parity=N,UART1,bits=8,stream = PORT1,errors)
#use rs232(baud=9600,parity=N,UART2,bits=8,stream = PORT2,errors)
My receive interrupt routines are like this:
#INT_RDA
void  RDA_isr(void)
   tmp=getc(PORT1);                             // get received char and thus also clear interrupt flag
   buffer[next_in]= tmp;                        // move received char to the appropriate place in buffer
   ++next_in;                                   // increment IN pointer
   if(next_in==BUFFER_SIZE) {                   // if we have 32, go back to 0
      next_in=0;
and the second:
#INT_RDA2
void  RDA2_isr(void)
   tmp2=getc(PORT2);                            // get received char and thus also clear interrupt flag
   UART2_buffer[next_in_UART2]= tmp2;           // move received char to the appropriate place in buffer
   ++next_in_UART2;                             // increment IN pointer
   output_toggle(LED);
   if(next_in_UART2 == UART2_BUFFER_SIZE) {     // if we have 16, go back to 0
      next_in_UART2 = 0;
I'm sending a string over from uart1 to uart2 every second in main:
const char GAME[] = "TEST\r\n";
   while(TRUE){
      UART1_Send(GAME);
My problem is that when it goes over the air, I get only the first two characters of the string in UART2_buffer, over and over. No nulls, nothing. If I connect TX from uart1 to RX of uart2 directly, everything works as expected. I have a serial-usb adapter connected, listening to the traffic. I have correct string going to the transmitter and, that is what confuses me, also the correct string coming out of the receiver and going to RX2 (that is where I listen with a terminal). It doesn't work on 3,3V, nor with 5V (here levels might be wrong). I tried different oscillator speeds, no change. Is it possible I have some kind of baud rate problem? If so, how can I detect that?
Regards,
Samo
PostPosted: Sun Feb 16, 2020 7:28 am     Reply with quote
Show us the UART1_Send routine.
Two characters, sounds like the routine is returning as soon as the UART
transmit buffer goes full, rather than looping till all the data is loaded.
From a 'standing start', the UART hardware can accept two characters.
PostPosted: Sun Feb 16, 2020 7:29 am     Reply with quote
Post your main().
PrinceNai
PostPosted: Sun Feb 16, 2020 7:43 am     Reply with quote
#include <i_transmit.h>
#INCLUDE <ctype.h>
#BYTE RCSTA2 = 0xF71
//#define LED PIN_A5
#define LED PIN_B5
#define HC12_SET PIN_E0
#define HC12_SET_2 PIN_E1
// Set of AT commands. I need 4 commands:
const char AT[] = "AT\r\n";                     // Every AT command starts with "AT". Answer = "OK"
const char CHANNEL_COMMAND[] = "AT+C0";         // set channell, the module returns "COK+C0XX"
const char FU[] = "AT+FU3\r\n";                 // set function. the module returns "AT+0K" NE, "OK+FU3"
const char POWER[] = "AT+P5\r\n";               // set power level. the module returns "OK+P1"
const char VERSION[] = "AT+V\r\n";              // get version. the module returns version
const char HC12_SLEEP[] = "AT+SLEEP\r\n";       // put the module to sleep. current consumption is 22uA
const char UART_MODE[] = "AT+U8N1\r\n";
const char UART_SPEED[] = "AT+B9600\r\n";
const char GAME[] = "TEST\r\n";                // send info to receiver that the game has finished
char CHANNEL_SELECT[5];
int8 Counter = 0;
char tmp;
int8 HC12_State = 0;       // state variable
int8 HC12_Response = 0;
enum {NO_RESPONSE, OK_RESPONSE, CHANNEL_OK_RESPONSE, POWER_OK_RESPONSE, FUNCTION_OK_RESPONSE, SPEED_OK_RESPONSE};          // answers from HC_12
#define CORRECT_ANSWER 1
#define WRONG_ANSWER -1
signed int8 Response;
#define BUFFER_SIZE 16                          //create 16 byte large buffer
char buffer[BUFFER_SIZE];
int8 next_in = 0;                               //max. next_in =  BUFFER_SIZE -1 !!!!!
#define  UART2_BUFFER_SIZE 60                   //create 16 byte large buffer
char UART2_buffer[UART2_BUFFER_SIZE];
int8 next_in_UART2 = 0;                         //max. next_in =  BUFFER_SIZE -1 !!!!!
char tmp2;
int8 HC12_Receiver_Get = 0;                     // state variable
char DIP_STATE;
int8 Game_Completed_Message = 0;
int8 Send_Game_Message = 0;
// ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff
void UART1_Send(char *s);
void UART2_Send(char *s);
// determine channel with respect to DIP switch setting
void Determine_Channel(void){
   if(DIP_STATE == 0){
      CHANNEL_SELECT = "01\r\n";
   else if(DIP_STATE == 1){
      CHANNEL_SELECT = "07\r\n";
   else if(DIP_STATE == 2){
      CHANNEL_SELECT = "13\r\n";
   else if(DIP_STATE == 3){
      CHANNEL_SELECT = "19\r\n";
   else if(DIP_STATE == 4){
      CHANNEL_SELECT = "25\r\n";
   else if(DIP_STATE == 5){
      CHANNEL_SELECT = "31\r\n";
   else if(DIP_STATE == 6){
      CHANNEL_SELECT = "37\r\n";
   else if(DIP_STATE == 7){
      CHANNEL_SELECT = "43\r\n";
   else if(DIP_STATE == 8){
      CHANNEL_SELECT = "49\r\n";
   else if(DIP_STATE == 9){
      CHANNEL_SELECT = "55\r\n";
   else if(DIP_STATE == 10){
      CHANNEL_SELECT = "61\r\n";
   else if(DIP_STATE == 11){
      CHANNEL_SELECT = "67\r\n";
   else if(DIP_STATE == 12){
      CHANNEL_SELECT = "73\r\n";
   else if(DIP_STATE == 13){
      CHANNEL_SELECT = "79\r\n";
   else if(DIP_STATE == 14){
      CHANNEL_SELECT = "85\r\n";
   else if(DIP_STATE == 15){
      CHANNEL_SELECT = "91\r\n";
   else{
//------------------ Send command or data to UART1 -----------------------
void UART1_Send(char *s)                        // Send command or data string
   while(*s) {                                  // as long as you don't encounter NULL
      fputc(*s++, PORT1);                              // send characters to selected UART1
void UART2_Send(char *s)                        // Send command or data string
      fputc(*s++, PORT2);                              // send characters to selected UART1
// iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii
#INT_EXT
void  EXT_isr(void)
#INT_TIMER0
void  TIMER0_isr(void)
#INT_RDA2
void  RDA2_isr(void)
//   if((RS232_ERRORS & 0x04)==0x04){
   if((RS232_ERRORS)){
      delay_cycles(1);
   output_toggle(LED);
      next_in_UART2 = 0;
#INT_RDA
void  RDA_isr(void)
      next_in=0;
#INT_TIMER1
void  TIMER1_isr(void)
   delay_cycles(1);
// end_i_end_i_end_i_end_i_end_i_end_i_end_i_end_i_end_i_end_i_end_i_end_i_end_
   output_high(LED);                            // turn off LED
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_32);    //cca. 200 ms overflow
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);      //65,5 ms overflow
   clear_interrupt(INT_EXT);                    // prevent external int from firing at once
   enable_interrupts(INT_EXT_H2L);
   enable_interrupts(INT_RDA);
   enable_interrupts(INT_RDA2);
   DIP_STATE = input_c();
   DIP_STATE = DIP_STATE & 0b00001111;          // mask upper four bits
   Determine_Channel();                         // get the desired channel from DIP switches
   delay_cycles(1);
// init the first HC-12
   output_low(HC12_SET);                        // put HC_12 in command mode, able to receive AT commands
   delay_ms(200);                               // wait for HC_12 to enter command mode
   UART1_Send(AT);                               // query module for life signs
   delay_ms(200);
   UART1_Send(AT);
   delay_ms(200);
   UART1_Send(AT);
   delay_ms(200);
   UART1_Send(AT);
   delay_cycles(1);
   delay_ms(200);
   UART1_Send(CHANNEL_COMMAND);                  // send fixed part of the command
   UART1_Send(CHANNEL_SELECT);                   // send variable channel select part + CR + NEWLINE
   delay_cycles(1);
   delay_ms(200);
   UART1_Send(FU);
   delay_cycles(1);
   delay_ms(200);
   UART1_Send(POWER);
   delay_cycles(1);
   output_high(HC12_SET);                       // exit command mode
   delay_ms(200);                               // wait a bit for the module to safely enter UART mode
// end first HC-12 init
// init the second one
   output_low(HC12_SET_2);
   delay_ms(200);
   UART2_Send(AT);                               // query module for life signs
   delay_ms(200);
   UART2_Send(AT);
   delay_ms(200);
   UART2_Send(AT);
   delay_ms(200);
   UART2_Send(AT);
   delay_cycles(1);
   delay_ms(200);
   UART2_Send(CHANNEL_COMMAND);                  // send fixed part of the command
   UART2_Send(CHANNEL_SELECT);                   // send variable channel select part + CR + NEWLINE
   delay_cycles(1);
   delay_ms(200);
   UART2_Send(FU);
   delay_cycles(1);
   delay_ms(200);
   UART2_Send(POWER);
   delay_cycles(1);
   output_high(HC12_SET_2);                     // exit command mode
   while(TRUE){
      UART1_Send(GAME);
h file:
#include <18f46k22.h>
#device PASS_STRINGS = IN_RAM    //copy all the strings to RAM to allow access with pointers
#device ADC=10
//#FUSES NOEXTOSC                 //External Oscillator not enabled
#FUSES PUT                      //Power Up Timer
//#FUSES LPBOR                    //Low-Power Brownout reset is enabled
//#FUSES BORV27                   //Brownout reset at 2.7V
#device ICD=TRUE
#use delay(internal=4000000)
//#pin_select U1TX = PIN_C4
//#pin_select U1RX = PIN_C5
//#use rs232(baud=9600,parity=N,xmit=PIN_C4,rcv=PIN_C5,bits=8,stream=HC-12,errors)
PrinceNai
PostPosted: Fri Feb 28, 2020 1:33 pm     Reply with quote
Dear Sirs,
Today I built a second, identical board. The same firmware loaded to both, HC-12 connected to Uart1. They are chatting without a glitch. The only thing that comes to my mind is the presence of a debugger (Pickit3) with the use of both Uarts.
Regards,
Samo
PostPosted: Fri Feb 28, 2020 4:08 pm     Reply with quote
you need to compile in 'release' mode for the 'real world'. Any 'debugger' has to change fuses, adds code for 'testing' purposes.....
PrinceNai
PostPosted: Sat Feb 29, 2020 7:10 am     Reply with quote
Done. I only have one Pickit3 at hand, so one board is programmed in release mode (both #FUSES DEBUG and #device ICD=TRUE removed) and the second one in debug mode. Works.
PostPosted: Sat Feb 29, 2020 9:20 am     Reply with quote
Read the DEV revision ID on the faulty board. There is a UART erratum that
only applies to revision A2 of the chip. Might well cause your problems.
