Long Interrupt
gtx15
Long Interrupt
PostPosted: Sat Feb 15, 2020 6:34 pm     Reply with quote
Trying to find a easy way to create a @ 1 minute interrupt. Must I use multiple shorter interrupts and count them?
Thank You.
PostPosted: Sat Feb 15, 2020 8:08 pm     Reply with quote
You could use combination of a slow (like 32kHz) secondary oscillator for one of your timers and also use a clock divider in the setup.
or you can use an real time clock and set an alarm interrupt.
I'm sure there are other options. A lot depends on your PIC and you haven't really given much information.
PostPosted: Sun Feb 16, 2020 6:57 am     Reply with quote
Have a look at the code here...
http://www.ccsinfo.com/forum/viewtopic.php?t=26177
It's a timer based RTC. You can easily modify to have the ISR set a 'one_minute_flag' that main() would read.
There are dozens of ways to accomplish what you want, but you should post which PIC you're using. Not all PICs have all internal peripherals !
