ertansuluagac
| I want to get the sine wave using excel. |
Posted: Thu Dec 26, 2019 9:21 am |
hello everyone.
PIC16F1784 dac output from I want to get the sine wave using excel.
How can I do?
The outputs for the sine wave was calculated as follows, the values were rounded to the nearest integer value:
#define WAVE_POINTS 100
DEGREE_INC_VALUE = 360 / WAVE_POINTS = 360 / 100 =
DEGREE_INC_VALUE = 3.6
For outputs 0 - 99:
Output[i] = (DAC_MAX_VALUE / 2) (sin(i * DEGREE_INC_VALUE) + 1) _________________ Es |
Posted: Thu Dec 26, 2019 10:02 am |
One way is to send the data as 'CSV' (Comma Separated Variables) to a PC terminal program and have it save to a file (maybe named 'DACoutput.CSV')
You then open Excel and import' 'DACoutput.CSV'.
The numbers wll 'magically' be put into a spreadsheet.
You should also send 'start of data', 'end of data' markers just so you know all data is sent.
ertansuluagac
Posted: Thu Dec 26, 2019 10:38 am |
ex_sine.c in made in this sample from ccs .how these values are formed. and how it applies to Excel. | Code: |
BYTE CONST SINE_WAVE[200] = {
128,132,136,139,143,147,150,154,158,161,165,169,172,176,179,
182,186,189,192,195,199,202,204,207,210,213,215,218,220,223,
225,227,229,231,233,235,237,238,240,241,242,243,244,245,246,
247,247,247,248,248,248,248,248,247,247,247,246,245,244,243,
242,241,240,238,237,235,233,231,229,227,225,223,220,218,215,
213,210,207,204,202,199,195,192,189,186,182,179,176,172,169,
165,161,158,154,150,147,143,139,136,132,128,124,120,117,113,
109,106,102,98,95,91,87,84,80,77,74,70,67,64,61,57,54,52,49,
46,43,41,38,36,33,31,29,27,25,23,21,19,18,16,15,14,13,12,11,
10,9,9,9,8,8,8,8,8,9,9,9,10,11,12,13,14,15,16,18,19,21,23,
25,27,29,31,33,36,38,41,43,46,49,52,54,57,61,64,67,70,74,77,
80,84,87,91,95,98,102,106,109,113,117,120,124}; |
Posted: Thu Dec 26, 2019 12:31 pm |
here's what I think
1st sine waves are AC( + and - values) , PIC DAC is DC ( +ve only)
Those numbers represent an 'offset' sine wave broken into 200 points. So 360* / 200 = 1.8* ( * means degrees) uisng 8 bit 'math'.
The numbers are unsigned integers ( 0 - 255)
'128' is the middle and so represents the 'zero' voltage line
'248' represent the maximum positive level
'8' represents the maximum negative level
The more 'points', the smoother the sinewave will be,but requires more time to create it. Usually you add an R-C filter to the DAC output and you'll get a very nice 'sine' wave. Using a 16 or 32bit DAC will result in an even better 'sine wave' but costs more money in hardware.
Others will reply,hopefully with better explanations.
ertansuluagac
Posted: Thu Dec 26, 2019 1:03 pm |
how do i apply these values to excel. I want to see the sinus wave in excel. _________________ Es |
ertansuluagac
Posted: Thu Dec 26, 2019 1:24 pm |
how create this values.
#define WAVE_POINTS 100 | Code: |
const int8 sine_output[WAVE_POINTS] = {128, 136, 143, 151, 159, 167, 174, 182, 189, 196,
202, 209, 215, 220, 226, 231, 235, 239, 243, 246,
249, 251, 253, 254, 255, 255, 255, 254, 253, 251,
249, 246, 243, 239, 235, 231, 226, 220, 215, 209,
202, 196, 189, 182, 174, 167, 159, 151, 143, 136,
128, 119, 112, 104, 96, 88, 81, 73, 66, 59,
53, 46, 40, 35, 29, 24, 20, 16, 12, 9,
6, 4, 2, 1, 0, 0, 0, 1, 2, 4,
6, 9, 12, 16, 20, 24, 29, 35, 40, 46,
53, 59, 66, 73, 81, 88, 96, 104, 112, 119}; |
dyeatman
Posted: Thu Dec 26, 2019 1:37 pm |
Go here to learn how to create a graph in Excel.
https://www.workzone.com/blog/how-to-make-a-graph-in-excel/
Using that info it took me 5 minutes to create the graph using your data.
I saved the values to a CSV file (with no CRLFs except at the end) then opened the file in Excel which created one row of data.
I then used Insert Graph and selected the data to create the graph of a clean sine wave. _________________ Google and Forum Search are some of your best tools |
ertansuluagac
Posted: Thu Dec 26, 2019 2:05 pm |
using these values I see the sine wave. How do I make these values. so , this numbers how can create?
how these numbers are calculated. I wrote a formula above. I think when I apply this formula to excel, these numbers occur. te te how do I apply that formula to excel.
this formula;
For outputs 0 - 99:
Output[i] = (DAC_MAX_VALUE / 2) (sin(i * DEGREE_INC_VALUE) + 1) |
ertansuluagac
Posted: Fri Dec 27, 2019 12:50 am |
does anyone know how it occurs these values?
yes, from excel in these values very beautiful sinus waves see. but, how it occurs these values _________________ Es |
ertansuluagac
Posted: Fri Dec 27, 2019 2:52 am |
[SOLVED]
the problem is solved.
thanks _________________ Es |
