LCD menu with keypad
bearzalk
PostPosted: Tue Nov 19, 2019 12:48 am     Reply with quote
I have a problem with my menu integration. I am currently using keypad to switch menu sections like when I press 'A' on keypad go to a sub-menu or press 'B' to go another sub-menu, when I press '*' inside of these sub-menus then go back to main menu.
I don't have any problem about going to sub-menus when program started but after I press '*' to go to main menu, I can't go back to any of sub-menus.
The code is as following:
char K;
char T;
void MainMenu()
   do
   K = kbd_getc();
   T = K - 48;
   lcd_gotoxy(1,1);
   printf(lcd_putc,"A)MOD B)SET HOUR");
   delay_ms(5);
   if((K=='A') || (K=='B') ||(K=='C') || (K=='D'))
   printf(lcd_putc,"\f U is zero now");
   U=0;
   }while(U==1);
void AltMod()
lcd_gotoxy(21,1);
printf(lcd_putc, "\fPRESS * FOR MAIN MENU\n");
delay_ms(5);
lcd_gotoxy(1,2);
printf(lcd_putc,"ENTER NUM=>\n");
void AltModRun()
do
   K = kbd_getc();
   T = K - 48;
   if((K!=0) && (K!='A') && (K!='B') && (K!='C') && (K!='D')&& (K != '*') && (K != '#'))
     A = (A*10) + T;
     //Don't add Y=20 here, it resets it to 20 in every cycle
     Y++;
     lcd_gotoxy(Y,1);
     printf(lcd_putc,"PRESS # FOR SUBMIT %d",T);
     delay_ms(5);
   if(K=='#')
     num= A;
     lcd_gotoxy(21,2);
     printf(lcd_putc,"%d NUM IS CHOSEN", num);
     delay_ms(5);
   if(K == '*')
   printf(lcd_putc,"\fINSIDE MOD STAR");
   Y=20;
   Z=0;
   A=0;
}while(Z==1);
kbd_init();
port_b_pullups(true);
set_tris_b(0xF0);
rtc_init();
MainMenu();//To display Main menu when program starts
while(true)
K = kbd_getc();
T = K - 48;
switch(K)
case 'D':
Z=1;
AltMod();
AltModRun();
case '*':
U=1;
printf(lcd_putc, "\fINSIDE CASE STAR");
//MainMenu();
If there is only printf inside case '*' then program works as I want, but when I comment out the printf and put MainMenu(); in there then it doesn't go to anywhere after I press '*', it keeps displaying main menu.
In program's first execution, when I press 'D' then it goes to sub menu, when I press * it goes back to main menu but while in main menu it doesn't go to sub menu when I press A,B,C or D, it only goes to sub menu when I press one of these keys around 20 times.
Re: LCD menu with keypad
PostPosted: Wed Nov 20, 2019 7:55 am     Reply with quote
This sounds like a problem with your usage of the kbd_getc() function.
The program in this post shows how to use a timer interrupt to call
the kbd_getc() function every 10 ms.
http://www.ccsinfo.com/forum/viewtopic.php?t=42707&start=4
bearzalk
PostPosted: Wed Nov 20, 2019 8:51 am     Reply with quote
Thanks a lot for reply, I'll try this. Just a quick question, why does it work when there is only printf in case '*' and can you check this topic sometimes because I'll update the status after I try your solution, I'd like to get your help if this solution does not work.
