raza741
| #locate error with typedef structure initializing. |
Posted: Wed Oct 16, 2019 9:34 pm |
Hi Everyone,
I am using IDE version 5.030, with dsPic 33EP512MU814.
The code below is not compiling correctly
static unsigned int16 senPrsData[3]={0,200,800};
#locate senPrsData = 0x1514
#define pressure_is_on senPrsData[0]
#define prs_alarm_min senPrsData[1]
#define prs_alarm_max senPrsData[2]
typedef struct _Sensor_Detection
unsigned int16 *senEnable;
signed int16 *senMaxThreshold;
signed int16 *senMinThreshold;
} Sensor_Detection;
static Sensor_Detection senPumpPres = {&pressure_is_on, &prs_alarm_max, &prs_alarm_min};
So what is happening is that when I remove
| Code: | | #locate senPrsData = 0x1514 |
it compiles correctly and I get the correct address in the structure "senPumpPres", address which are actually compiler it self assigned.
But when I use "#locate", it assign the correct addresses to senPrsData[] array, starting from 0x1514, but all the members in structure "senPumpPres" are assigned the same value which is 0x1514. where as it should assign 0x1514, 0x1516 and 0x1518.
Is there any issue with the compiler or am I doing something completely wrong.
Sorry if I did not follow the forum policies correctly. Thanks In advance.
Raza |
Posted: Thu Oct 17, 2019 1:40 am |
Seriously, big red flag. 5.030!...
What is happening, is the compiler is taking the address of the variable,
and not the sub component, but then doesn't know how to add the offset
to reach the required part.
Ugh.
It is fixed a few versions later.
With 5.040:
00220: MOV #1514,W4
00222: MOV W4,1000
00224: MOV #1518,W4
00226: MOV W4,1002
00228: MOV #1516,W4
0022A: MOV W4,1004
As you can see, correctly placing the pointers to the three different
locations.
It looks as if the act of 'locating' the variable, is making the compiler
'forget' it's array nature.
You can (of course), cheat:
static Sensor_Detection senPumpPres = {senPrsData, senPrsData+1, senPrsData+2};
No. Just tested, and on your compiler this does the same thing:
00220: MOV #1514,W4
00222: MOV W4,1000
00224: MOV #1514,W4
00226: MOV W4,1002
00228: MOV #1514,W4
0022A: MOV W4,1004
It seems to be fundamentally 'hiccuped', when handling pointers to
a #located variable.
Only workround I have found is to work 'through' a variable. So:
const byte * locn = senPrsData;
static Sensor_Detection senPumpPres = {locn, locn+2, locn+4};
Correctly generates the required addresses.... |
raza741
Posted: Thu Oct 17, 2019 3:24 pm |
Thanks for you help Ttelmah.
We used to update the compiler regularly before and what ends up happening was it sometimes introduces new bugs which was then hard to find that if any other part of the code get effected. So we stopped updating after 5.030.
I guess I have to do the workaround as you suggested. As it's still better than initializing every element of the structure one by one. |
Posted: Thu Oct 17, 2019 11:23 pm |
Why not just keep multiple versions?. I have probably 100 versions of
the compiler all installed. When working on code, I note as part of the
comments at the top of the program, the compiler version being used.
Then when a new version is launched, I try and see if everything still
works. If it does I update the version to use.
I've had programs that refused to update between versions on about
three occasions. In each case a little work later gave me a version
that became compatible. Problems like this were quite common with
V5, and particularly the first few compilers after this launched. The newer
compilers do have a lot of new features and quite a few improvements,
so it is worth considering trying at least one update. |
