allenhuffman
Joined: 17 Jun 2019 Posts: 537 Location: Des Moines, Iowa, USA
Debugger: is it possible to change the value or a variable? |
Posted: Wed Jul 03, 2019 7:53 am |
I've worked with debuggers that allow me to alter the value of a variable while the program is paused. My search through the help file didn't seem to indicate this was possible.
Is there a way to alter a variable inside the debugger? I am running without any type of console, and would like to be able to alter a variable during debugging to run different test functions without having to alter code and rebuild each time.
Thanks! _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ? |
E_Blue
Posted: Wed Jul 03, 2019 8:45 am |
What IDE are you using?
With MPLAB IDE is pretty easy.
Open a Watch Window add the variable, run the code, halt the code, edit the variable and run again. _________________ Electric Blue |
allenhuffman
Posted: Fri Jul 05, 2019 9:56 am |
E_Blue wrote: | What IDE are you using?
Open a Watch Window add the variable, run the code, halt the code, edit the variable and run again. |
Alas, we use CCS C Compiler's IDE. Thanks. It is good to know there is an option out there if we are ever able to switch. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
