No compiler error using #ROM beyond Data EEROM space
avatarengineer
PostPosted: Sat Jun 29, 2019 2:23 pm     Reply with quote
Compiler = PICC 5.085
Device = 16F1788 with 256 bytes of EEROM
Interest is to preload EEROM space with data;
#DEFINE EEMEMSTART getenv("EEPROM_ADDRESS")
#DEFINE EESTATMEM EEMEMSTART+300
#ROM EESTATMEM={0xF,0xF}
Start address of Data EEROM (0xF000) + 300
is obviously more than 256 bytes
therefore a compiler error should be reported
when I attempt to compile 2 bytes at 0xF12C
...but it doesn't.
Any comments on this?
Confused
PostPosted: Sun Jun 30, 2019 4:39 am     Reply with quote
I'll take a 'stab' at it....
I downloaded the datasheet and the 256 bytes of EEPROM are accessed differently than 'regular' memory according to section 3.0 'memory organization. To access the 256 bytes of DATA EEPROM, you need to see section 12.
The address you post 0xF000 is within the 'normal' memory map (see figure 3.8). It's the Program Flash memory section. As such it's a valid address.
Only had 1 coffee so far, so I might be wrong..
PostPosted: Sun Jun 30, 2019 11:39 am     Reply with quote
If you want an error message over this, email CCS and ask them to
put it in. But be aware that there will be some bugs introduced, at least
initially, if they do this. Some PICs will throw an error if you do correctly.
Then you'll have to report it, and wait for the next revision or maybe
get a temporary DLL fix.
I don't think it's worth it. Just read the data sheet carefully.
