IDE Reset bookmarks
soonc
IDE Reset bookmarks
PostPosted: Fri Jun 07, 2019 9:36 am     Reply with quote
Does anyone know: How can I reset all bookmarks in the PCWHD IDE ?
If I close a file and open a different file the bookmarks are still referencing the closed file!
This gets really confusing when running two instances of the IDE.
PostPosted: Fri Jun 07, 2019 10:02 am     Reply with quote
On the toolbar at the top. Search.
Then you should have two buttons shown, for 'toggle' and 'goto'.
On the right of the toggle button, there is a small arrow. Click on it.
Bottom of the box that drops down, there is a tab 'Remove All'.
The same tab is available if you right click on the page, and again
select 'Toggle Bookmark'.
soonc
Not on menu
PostPosted: Fri Jun 07, 2019 1:06 pm     Reply with quote
Thanks... I don't use the toolbar as it eats too much space.
I don't normally use the menu for bookmarks just the keyboard.
It is there under "Edit/Toggle" the bottom of the sub menu but has not Keys assigned to it.
I assigned Ctrl+Alt+R, that works.
Thanks for the help.
PostPosted: Fri Jun 07, 2019 10:16 pm     Reply with quote
Must admit 'not exactly obvious'.... Smile
Glad you have it sorted.
