José Aparecido
| Conversion Library |
Posted: Thu Jun 06, 2019 5:16 pm |
Hi, I'm developing a project using a PIC18F4550 microcontroller and an LM044L LCD display. I need a library that converts hexadecimal values (int) to decimals.
Then I will display these decimal values on the LCD display.
Does anyone know where I can find such a library? Or how can I convert the values? Thanks. |
Posted: Fri Jun 07, 2019 4:23 am |
just a helpful hint..
... while your project is open, pressing F11 will display the CCS Manual, when using MPLAB.
it's always there when I'm cutting code...
Posted: Fri Jun 07, 2019 8:04 am |
and just as a further comment to this, since it is not said where these numbers
are actually coming 'from', if they are hexadecimal, then 'atoi', is the function
to convert ASCII to an integer. |
